# How to sum 2 saved context values
**URL:** <https://discourse.nodered.org/t/how-to-sum-2-saved-context-values/69430>\
**Created:** [22 October 2022 14:35 UTC](https://discourse.nodered.org/t/how-to-sum-2-saved-context-values/69430 "2022-10-22T14:35:18Z")\
**Showing post:** 14
**Author:** ![Walt\_Dod](https://avatars.discourse-cdn.com/v4/letter/w/e9a140/32.png) [@Walt\_Dod](https://discourse.nodered.org/u/Walt_Dod)\
**Post date:** [27 October 2022 09:03 UTC](https://discourse.nodered.org/t/how-to-sum-2-saved-context-values/69430/14 "2022-10-27T09:03:40Z")
Hi Paul,
The uncommenting of my last mail (see below) did work for a while but not any more...
I had a look on
> [@Fun With Persistence?](https://discourse.nodered.org/t/fun-with-persistence/33189/2):
> Hi @Nodi.Rubrum that is strange. When I use the same contextStorage setting as you have, then the editor knows I have multiple context stores and the UI reflects that. For example, the Change node (and all other users of the TypedInput widget) offers an option on which store to use: The Context sidebar includes labels for the store a value is in: In the developer console of your browser, can you enter RED.settings.context and see what its value is?
and found i had the same issue as described about the store use, whether default or persistent, which do not appear in the change node settings on my screen. I tried deleting the coma in the settings.json file as shown, whith no avail...
Maybe you can help ?
Regards,
Walt
Hi Paul,
As the watt2kwh node was set with your help in context mode to avoid data influence from one node to the next,
it seems that I only had to uncomment
**_contextStorage: {_**
**_default: {_**
**_module:"localfilesystem"_**
**_},_**
**_},_**
in **settings.js** to have the stored kwh data saved in the dashboard when redeploying...
W.
**Envoyé:** mardi 25 octobre 2022 à 10:22
_[View the full topic](https://discourse.nodered.org/t/how-to-sum-2-saved-context-values/69430)._
