# How to tell the difference between \\n in a string and a newline?
**URL:** <https://discourse.nodered.org/t/how-to-tell-the-difference-between-n-in-a-string-and-a-newline/77922>\
**Tags:** function-node\
**Created:** [25 April 2023 14:09 UTC](https://discourse.nodered.org/t/how-to-tell-the-difference-between-n-in-a-string-and-a-newline/77922 "2023-04-25T14:09:00Z")\
**Showing post:** 9
**Post date:** [25 April 2023 15:05 UTC](https://discourse.nodered.org/t/how-to-tell-the-difference-between-n-in-a-string-and-a-newline/77922/9 "2023-04-25T15:05:54Z")
Try
let lines = file.split(/(?<!:)\n/)
But it would be best to correct the code and remove non valid property characters from your property names, then you would not have to patch the issue.
Just for info
const foo = file.replace( ":\n", ":::")
will only replace first occurance.
it should be
const foo = file.replace( /:\n/g, ":::")
for multiple replaces.
_[View the full topic](https://discourse.nodered.org/t/how-to-tell-the-difference-between-n-in-a-string-and-a-newline/77922)._
