# Https with an extern certificate
**URL:** <https://discourse.nodered.org/t/https-with-an-extern-certificate/78183>\
**Created:** [4 May 2023 12:16 UTC](https://discourse.nodered.org/t/https-with-an-extern-certificate/78183 "2023-05-04T12:16:17Z")\
**Showing post:** 7
**Author:** ![lu4t](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/lu4t/32/32276_2.png) [@lu4t](https://discourse.nodered.org/u/lu4t)\
**Post date:** [15 May 2023 22:33 UTC](https://discourse.nodered.org/t/https-with-an-extern-certificate/78183/7 "2023-05-15T22:33:01Z")
if you want to expose the node-red dashboard to the outside world over a https connection, and you already own a domain, you can use the method explained on this post:
> [@Free and SSL secured access to your node-red instance running on a Raspberry Pi](https://discourse.nodered.org/t/free-and-ssl-secured-access-to-your-node-red-instance-running-on-a-raspberry-pi/64112):
> Some months back, I published a video showing how to use cloudflare tunnels to access node-red running on a Synology NAS. I told @cymplecy on this [post](https://discourse.nodered.org/t/remote-free-and-secure-access-to-your-node-red-instance-at-home/60353) I would grab my old RPi and record a video showing how to get the same result if node-red was running on a RPi as a host. Well, this is the result of the "promise" I did. Hoping the community can take advantage of it also: [[HOW TO: Remote access a Raspberry Pi using a Cloudflare tunnel (node-red and ssh).] ](https://www.youtube.com/watch?v=Z6b3l1z0N7w) Take care! …
The cloudflare account that allows to do this is free (even if your register is not cloudflare).
_[View the full topic](https://discourse.nodered.org/t/https-with-an-extern-certificate/78183)._
