C:\Users\oee.hsr>node-red
11 Apr 14:22:40 - [info]
Welcome to Node-RED
11 Apr 14:22:40 - [info] Node-RED version: v3.1.8
11 Apr 14:22:40 - [info] Node.js version: v18.19.0
11 Apr 14:22:40 - [info] Windows_NT 10.0.22631 ia32 LE
11 Apr 14:22:41 - [info] Loading palette nodes
11 Apr 14:22:42 - [info] Settings file : C:\Users\oee.hsr\.node-red\settings.js
11 Apr 14:22:42 - [info] Context store : 'default' [module=memory]
11 Apr 14:22:42 - [info] User directory : \Users\oee.hsr\.node-red
11 Apr 14:22:42 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Apr 14:22:42 - [info] Flows file : \Users\oee.hsr\.node-red\flows.json
11 Apr 14:22:42 - [info] Creating new flow file
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
11 Apr 14:22:42 - [warn] Encrypted credentials not found
11 Apr 14:22:42 - [info] Server now running at http://127.0.0.1:1880/
11 Apr 14:22:42 - [info] Starting flows
11 Apr 14:22:42 - [info] Started flows
