I need to get the RAW body from a listener node
Hi @knolleary
I already started extending the 21-httpin.js with an additional option to expose the rawBody (same concept with the body-parser's verify function) but it didn't work. The current solution works just by modifiing the settings.js so no patching of Node-RED itself was necessary. But when you have a way / idea how to deal with the admin interface i could make out a PR out with my extensions...
Cheers, Chris
Some late praise @chrisnie, great work! Exactly what i was looking for. Also the use case of verifying sha256-hmac of the request, for auth purposes. In the mean time, has any progress been made integrating this into NodeRED proper @knolleary?
No - this dropped off my radar and no-one else picked it up.
Alright, thx for the update!
One more vote for the raw body option in http in nodes. Having the same issue with the request verification.
Another bump for this functionality. Request verification for webhooks fired from WooCommerce is also done by a hmac-SHA256 checksum over the body with a shared secret.
A bump for this functionality from me too. I’m trying to use the rawBody for validation of the Nextcloud webhooks app : GitHub - kffl/nextcloud-webhooks: Webhooks app for Nextcloud using SHA256.
@chrisnie Did not work for me. I am still getting parsed body
Added that and now node red won't load
You may have a syntax error in settings.js. What error do you see when you try to start node red?
Step 1: Identify current state
node-red before starting anything
22 Jun 16:39:41 - [info] Node-RED version: v2.2.2
22 Jun 16:39:41 - [info] Node.js  version: v12.22.12
22 Jun 16:39:41 - [info] Linux 5.13.0-1031-aws x64 LE
22 Jun 16:39:41 - [info] Loading palette nodes
22 Jun 16:39:42 - [info] Settings file  : /home/ubuntu/.node-red/settings.js
22 Jun 16:39:42 - [info] Context store  : 'default' [module=memory]
22 Jun 16:39:42 - [info] User directory : /home/ubuntu/.node-red
22 Jun 16:39:42 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 Jun 16:39:42 - [info] Flows file     : /home/ubuntu/.node-red/flows.json
your credentials.
22 Jun 16:39:42 - [error] Unable to listen on http://127.0.0.1:1880/
22 Jun 16:39:42 - [error] Error: port in use
Note I am not using the default port
Step 2: Enable httpNodeMiddleware
    httpNodeMiddleware: function(req,res,next) {
    //    // Handle/reject the request, or pass it on to the http in node by calling next();
    //    // Optionally skip our rawBodyParser by setting this to true;
       req.skipRawBodyParser = true;
       next();
...restart node red pm2 restart node-red
node-red provides same result
Running a flow with http in... input still parsed object
Step 3: Change the admin panel from my.domain.com to my.domain.com/admin
in settings.js, just enabled the
httpAdminRoot: '/admin',
... restart node red pm2 restart node-red
and check node-red
The terminal output is now different
22 Jun 16:51:47 - [info] Node-RED version: v2.2.2
22 Jun 16:51:47 - [info] Node.js  version: v12.22.12
22 Jun 16:51:47 - [info] Linux 5.13.0-1031-aws x64 LE
22 Jun 16:51:48 - [info] Loading palette nodes
22 Jun 16:51:48 - [info] Settings file  : /home/ubuntu/.node-red/settings.js
22 Jun 16:51:48 - [info] Context store  : 'default' [module=memory]
22 Jun 16:51:48 - [info] User directory : /home/ubuntu/.node-red
22 Jun 16:51:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 Jun 16:51:48 - [info] Flows file     : /home/ubuntu/.node-red/flows.json
your credentials.
22 Jun 16:51:48 - [error] Unable to listen on http://127.0.0.1:1880/admin/
22 Jun 16:51:48 - [error] Error: port in use
Catching a new webhook... msg.payload is again an object
After changing the root directory, I also get a 404 error from Postman. The error is due to cryptojs library I manually added in node red. I assume the library cannot be accessed from the /admin directory
Step 4: Try the adding the code
Coded Added
var bodyParser = require('body-parser');
var jsonParserWithRawBody = bodyParser.json({
    verify: function (req, res, buf, encoding) {
        req.rawBody = buf;
in the very beginning - just above module.exports
Coded removed
Commented out the httpNodeMiddleware that I enabled in Step 2 and added the code above instead
        if (req.url === '/my/httpin/url/where/i/want/to/have/the/raw/body') {
           jsonParserWithRawBody(req, res, next);
        } else
           next();
...restart ... node-red
Error loading settings file: /home/ubuntu/.node-red/settings.js
ubuntu@ip-172-31-32-243:~$
Nothing works, I am exhausted
You have to stop the current node red instance from running before you start another one.
@Colin
I restarted the server and I am getting the same error. Maybe pm2 ? Is this relevant to the issue ?
If the port is already in use then almost certainly node red is already running.
The settings.js error means you have messed it up. Restore the previous version from your backup and start again.
Ok will try starting from scratch
@Colin Getting the same error on Ubuntu 20.04.4 LTS
The error appeared after installing pm2
Which error exactly?
I could not make this work. I highly discourage anyone trying it as it turned out an outrageous amount of time waste for me.
I used n8n instead
