# Icons under delay node
**URL:** <https://discourse.nodered.org/t/icons-under-delay-node/82318>\
**Created:** [25 October 2023 03:32 UTC](https://discourse.nodered.org/t/icons-under-delay-node/82318 "2023-10-25T03:32:32Z")\
**Showing post:** 10
**Post date:** [26 October 2023 11:54 UTC](https://discourse.nodered.org/t/icons-under-delay-node/82318/10 "2023-10-26T11:54:59Z")
The OP has opened another thread on their basic loop problem
> [@Fundamental misunderstanding of the loop node](https://discourse.nodered.org/t/fundamental-misunderstanding-of-the-loop-node/82341/6):
> OK so a couple of things here - most people will not have the Home Assistant nodes installed (i think i am one of the few on here that do) so you are better off asking questions in the Node Red subforum of the HA forums. (Not because we are rude but because most people do not want to pollute their systems with all the HA nodes and the baggage that they bring.) How long is the proposed check time for turning on and off (whatever it is you are controlling) Usually to do this i would use a trigge…
_[View the full topic](https://discourse.nodered.org/t/icons-under-delay-node/82318)._
