# IKEA motion sensor
**URL:** <https://discourse.nodered.org/t/ikea-motion-sensor/20781>\
**Created:** [23 January 2020 17:20 UTC](https://discourse.nodered.org/t/ikea-motion-sensor/20781 "2020-01-23T17:20:38Z")\
**Showing post:** 7
**Post date:** [24 January 2020 15:26 UTC](https://discourse.nodered.org/t/ikea-motion-sensor/20781/7 "2020-01-24T15:26:11Z")
You can do all that in one go using a Change node configured like this
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/d/c/dcb58f72a9f86319b8f6c4d942cb122efd074912.png)
That JSONata expression tests msg.payload.occupancy and if it is true sets the payload to ON, otherwise it sets it to OFF.
For future reference when you posting a flow do it as described in this post so that it is importable.
_[View the full topic](https://discourse.nodered.org/t/ikea-motion-sensor/20781)._
