Import a library by global method vs script src method
Let me show you with an example. Let´s say you want to use the library echarts.js.
I would do this way:
1- add the library to an ui_template node configuring in to be added to the <head> section of the site.
library-in-header
2- In you template node you can use the methods provided by the library inside script tags.
<script type="text/javascript">
    var dom = document.getElementById("divChart3");
    var myChart =null;
    myChart = echarts.init(dom);
    option = null;
    {{{payload}}}
    if (option && typeof option === "object")
        myChart.setOption(option, true);
</script>
