# Importing function from Node.js module
**URL:** <https://discourse.nodered.org/t/importing-function-from-node-js-module/77741>\
**Tags:** function-node\
**Created:** [20 April 2023 12:54 UTC](https://discourse.nodered.org/t/importing-function-from-node-js-module/77741 "2023-04-20T12:54:36Z")\
**Post date:** [20 April 2023 13:11 UTC](https://discourse.nodered.org/t/importing-function-from-node-js-module/77741/2 "2023-04-20T13:11:19Z")
Welcome to forums @dazfitzg.
You cant `require` or `import` in function nodes.
Please see a recent post on how to do it [Here](https://discourse.nodered.org/t/howto-use-assert/77718)
EDIT:
Seems you have already tried that 🤦‍♂️
> I removed the import and tried to add the module in the function node's setup tab.
_[View the full topic](https://discourse.nodered.org/t/importing-function-from-node-js-module/77741)._
