In Change Node, setting output of mySQL node to Flow.Context gives "[object Object]"
I have seen this behaviour before (with another node) - and I believe it has to do with the way it returns the object (not sure what the exact issue was), could you try to enable 'deep copy value' ?
edit found my own topic
