# InfluxDB errors - q-gate and check InfluxDB write is completed OK
**URL:** <https://discourse.nodered.org/t/influxdb-errors-q-gate-and-check-influxdb-write-is-completed-ok/33283>\
**Created:** [24 September 2020 12:53 UTC](https://discourse.nodered.org/t/influxdb-errors-q-gate-and-check-influxdb-write-is-completed-ok/33283 "2020-09-24T12:53:57Z")\
**Showing post:** 5
**Post date:** [28 September 2020 09:25 UTC](https://discourse.nodered.org/t/influxdb-errors-q-gate-and-check-influxdb-write-is-completed-ok/33283/5 "2020-09-28T09:25:13Z")
I had not realised which flow you had linked earlier, but there has been another discussion of a similar situation, but I can't find it at the moment. This is the flow we ended up with, which is rather simpler than the earlier one that you have used. I need to update that one.
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/3/c/3c22f7f289d7a153fca1f01a3473ad7553362e6c.png)
[{"id":"f82aed15.9f1a98","type":"q-gate","z":"bdd7be38.d3b55","name":"q-gate","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","peekCmd":"peek","dropCmd":"drop","statusCmd":"status","maxQueueLength":"100","keepNewest":false,"qToggle":false,"persist":false,"x":410,"y":1440,"wires":[["ae4b0558.378d8","b6aba10c.b691f"]]},{"id":"6ec96b3b.ec5c14","type":"debug","z":"bdd7be38.d3b55","name":"OK","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":2080,"wires":[]},{"id":"fed5956.ed73668","type":"inject","z":"bdd7be38.d3b55","name":"inject messages","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":1440,"wires":[["f82aed15.9f1a98"]]},{"id":"4ef6d24.5459eac","type":"inject","z":"bdd7be38.d3b55","name":"Retry","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"15","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"peek","payloadType":"str","x":90,"y":1620,"wires":[["a20949f9.306a48"]]},{"id":"4270c3f6.19012c","type":"delay","z":"bdd7be38.d3b55","name":"process","pauseType":"delay","timeout":"4","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":340,"y":1920,"wires":[["b0c78702.b01988"]]},{"id":"a8381ab7.d1949","type":"link out","z":"bdd7be38.d3b55","name":"","links":["5a2f45b9.929cc4"],"x":795,"y":2040,"wires":[]},{"id":"5a2f45b9.929cc4","type":"link in","z":"bdd7be38.d3b55","name":"","links":["a8381ab7.d1949"],"x":95,"y":1500,"wires":[["1ec5d8f7.0e6ae7"]]},{"id":"1ec5d8f7.0e6ae7","type":"function","z":"bdd7be38.d3b55","name":"get next","func":"node.send({topic: \"control\", payload: \"drop\"})\nmsg.topic = \"control\"\nmsg.payload = \"peek\"\nreturn msg;","outputs":1,"noerr":0,"x":200,"y":1500,"wires":[["f82aed15.9f1a98"]]},{"id":"672111d5.4f229","type":"inject","z":"bdd7be38.d3b55","name":"Simulate internet up","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"internet","payload":"up","payloadType":"str","x":230,"y":1980,"wires":[["edb0af2.fd1645"]]},{"id":"bc5fa483.adc8f","type":"inject","z":"bdd7be38.d3b55","name":"Simulate internet down","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"internet","payload":"down","payloadType":"str","x":230,"y":2020,"wires":[["edb0af2.fd1645"]]},{"id":"edb0af2.fd1645","type":"join","z":"bdd7be38.d3b55","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":470,"y":2000,"wires":[["b7feed8e.7caf68"]]},{"id":"b0c78702.b01988","type":"change","z":"bdd7be38.d3b55","name":"topic:data","rules":[{"t":"set","p":"topic","pt":"msg","to":"data","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":1920,"wires":[["edb0af2.fd1645"]]},{"id":"b7feed8e.7caf68","type":"switch","z":"bdd7be38.d3b55","name":"Data message?","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"data","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":380,"y":2080,"wires":[["d96e80be.41aff"]]},{"id":"d96e80be.41aff","type":"switch","z":"bdd7be38.d3b55","name":"OK/Fail?","property":"payload.internet","propertyType":"msg","rules":[{"t":"eq","v":"up","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":560,"y":2080,"wires":[["6ec96b3b.ec5c14","a8381ab7.d1949"],["ea9c5a96.2dcfe8","37735513.24d77a"]]},{"id":"ea9c5a96.2dcfe8","type":"debug","z":"bdd7be38.d3b55","name":"FAIL","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":2120,"wires":[]},{"id":"a20949f9.306a48","type":"gate","z":"bdd7be38.d3b55","name":"","controlTopic":"gate_control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":610,"y":1620,"wires":[["f82aed15.9f1a98"]]},{"id":"ae4b0558.378d8","type":"change","z":"bdd7be38.d3b55","name":"Close gate","rules":[{"t":"set","p":"topic","pt":"msg","to":"gate_control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":1580,"wires":[["a20949f9.306a48"]]},{"id":"a78ce065.5c9b68","type":"change","z":"bdd7be38.d3b55","name":"Open gate","rules":[{"t":"set","p":"topic","pt":"msg","to":"gate_control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":1720,"wires":[["a20949f9.306a48"]]},{"id":"e5978b76.2fb2b","type":"link in","z":"bdd7be38.d3b55","name":"","links":["b6aba10c.b691f"],"x":135,"y":1920,"wires":[["4270c3f6.19012c"]]},{"id":"b6aba10c.b691f","type":"link out","z":"bdd7be38.d3b55","name":"","links":["e5978b76.2fb2b"],"x":615,"y":1440,"wires":[]},{"id":"37735513.24d77a","type":"link out","z":"bdd7be38.d3b55","name":"","links":["7f6b726d.0cab2c"],"x":795,"y":2160,"wires":[]},{"id":"7f6b726d.0cab2c","type":"link in","z":"bdd7be38.d3b55","name":"","links":["37735513.24d77a"],"x":55,"y":1720,"wires":[["a78ce065.5c9b68"]]},{"id":"5d647435.11ea14","type":"comment","z":"bdd7be38.d3b55","name":"Processed ok","info":"","x":690,"y":2020,"wires":[]},{"id":"cda552d1.59b25","type":"comment","z":"bdd7be38.d3b55","name":"Failed","info":"","x":670,"y":2160,"wires":[]},{"id":"6777d4.5738d02c","type":"comment","z":"bdd7be38.d3b55","name":"Replace this with your message processing, sending a message to the Fail or Success outputs","info":"","x":350,"y":1820,"wires":[]},{"id":"d1158219.184d38","type":"comment","z":"bdd7be38.d3b55","name":"Messages to be processed come in here","info":"","x":200,"y":1880,"wires":[]},{"id":"4681668e.9d5cd8","type":"comment","z":"bdd7be38.d3b55","name":"Feed messages to be queued in here and remove Inject node","info":"","x":270,"y":1400,"wires":[]},{"id":"177f73a0.c29e2c","type":"status","z":"bdd7be38.d3b55","name":"","scope":["f82aed15.9f1a98"],"x":80,"y":1660,"wires":[["b95b8054.e3339"]]},{"id":"b95b8054.e3339","type":"function","z":"bdd7be38.d3b55","name":"Queue empty?","func":"// expects msg.status.text in form \"queuing: <number>\"\n// sends a message if queue is empty\nif (parseInt(msg.status.text.split(\":\")[1]) !== 0) {\n msg = null\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":320,"y":1660,"wires":[["a78ce065.5c9b68"]]},{"id":"e72ba10d.c92638","type":"comment","z":"bdd7be38.d3b55","name":"Set this to appropriate retry interval","info":"","x":150,"y":1580,"wires":[]},{"id":"384aef3e.b12c2","type":"debug","z":"bdd7be38.d3b55","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":610,"y":1740,"wires":[]}]
_[View the full topic](https://discourse.nodered.org/t/influxdb-errors-q-gate-and-check-influxdb-write-is-completed-ok/33283)._
