# Input needed for a fix in the dropbox node (refresh tokens)
**URL:** <https://discourse.nodered.org/t/input-needed-for-a-fix-in-the-dropbox-node-refresh-tokens/72949>\
**Created:** [30 December 2022 11:04 UTC](https://discourse.nodered.org/t/input-needed-for-a-fix-in-the-dropbox-node-refresh-tokens/72949 "2022-12-30T11:04:51Z")\
**Showing post:** 39
**Post date:** [6 January 2023 22:06 UTC](https://discourse.nodered.org/t/input-needed-for-a-fix-in-the-dropbox-node-refresh-tokens/72949/39 "2023-01-06T22:06:50Z")
The pull request has been submitted.
Announcement started in another discussion:
> [@\[ANNOUNCEMENT\] Dropbox node versie 2.1.0 (beta) - refresh token refactored](https://discourse.nodered.org/t/announcement-dropbox-node-versie-2-1-0-beta-refresh-token-refactored/73312):
> Hi folks, We introduced in version 2.0.0 of the dropbox node the concept of refresh tokens, to allow this node to support the new stronger Dropbox security guidelines. However our mechanism was based on OAauth2 redirect url's, which required the connection between Node-RED and the flow editor to be SSL with certificates signed by a trusted CA (e.g. LetsEncrypt). Normally it is bad practice to use plain HTTP, however when everything (flow editor, Node-RED, ...) is located in a secure LAN behin…
_[View the full topic](https://discourse.nodered.org/t/input-needed-for-a-fix-in-the-dropbox-node-refresh-tokens/72949)._
