# Install node red
**URL:** <https://discourse.nodered.org/t/install-node-red/23157>\
**Created:** [16 March 2020 06:01 UTC](https://discourse.nodered.org/t/install-node-red/23157 "2020-03-16T06:01:01Z")\
**Post date:** [16 March 2020 09:47 UTC](https://discourse.nodered.org/t/install-node-red/23157/4 "2020-03-16T09:47:05Z")
npm has two ways of installing modules - either as a local module or a global module.
When installed as a global module (by using the `-g` option) then it will place any scripts the module provides onto your path so they can be run from anywhere.
When installed as a local module (as you are doing here) then it does _not_ put the scripts onto your path.
To run node-red when it has been installed into a local directory you would run:
`node node_modules/node-red/red.js`
You may also want to look at [New Utility: alternate-node-red-installer](https://discourse.nodered.org/t/new-utility-alternate-node-red-installer/13490)
_[View the full topic](https://discourse.nodered.org/t/install-node-red/23157)._
