Hi, the command that is failing is actually a PowerShell command and you are using cmd.exe in that window. That is strange because it works for me.
What version of node.js is installed and have you tried to manually update npm?
I have v12.13.0 of node.js installed. I was able to get the desktop version installed but I get a similar error when I try to install the dashboard node. Something is definitely broken and I'm starting to wonder if this is even enhanced security. I will keep playing around with it and see if I can figure it out.
This sounds like the perfect use case for the Dockerised Node-RED
After installing it on a local directory how will we start node-red from the command line? Calling node-red says it is not recognized as internal or external command. I have installed nodejs and performed a local install to an offline machine. I would like to start node-red in the same now.
node c:\Users\Documents\NodeRed\node_modules\node-red\red.js
this seems to have solved my issue.
So basically what I have done is:
Of course, that won't work because that is most likely not in your PATH variable. So you have to use the absolute path.
Assuming NodeJS is in your PATH, you can start Node-RED manually by running
node [path to node-red]/node_modules/node-red/red.js
If you want to use the command line node-red you should find it in node_modules/.bin
Check out the alternate installer on my GitHub. It contains an npm script in the package.json that contains the command you need.
