Is an array as a payload not really an array?
My payload is an array:
Bildschirmfoto vom 2021-11-01 18-34-48
but
msg.payload.forEach((item) => {
gave me an error:
"TypeError: msg.payload.forEach is not a function"
So I used
Array(msg.payload).forEach((item) => {
and that worked.
But why didn't the first method?
Can you export and share that part of your flow with the sample data of msg.payload to demostrate the problem ?
Where has that value come from? It is possible its a non-Array type that looks enough like an Array for the sidebar to report it as such.
You could try adding a Function node with:
node.warn("Array.isArray: "+Array.isArray(msg.payload))
node.warn("typeof: "+(typeof msg.payload))
return msg
to get some more information on what the property actually is.
Wow, you guys are fast. And good call, it's not a true Array:
function : (warn)
"Array.isArray: false"
11/1/2021, 6:50:43 PMnode: 6ccdb2532bf27083function : (warn)
"typeof: object"
The payload came from a file through an xml and a few splits.
Thank you!
