# Is it possible to tile the groups in node-red-dashboard vertically?
**URL:** https://discourse.nodered.org/t/is-it-possible-to-tile-the-groups-in-node-red-dashboard-vertically/71990
**Category:** Dashboard
**Created:** [10 December 2022 11:46 UTC](https://discourse.nodered.org/t/is-it-possible-to-tile-the-groups-in-node-red-dashboard-vertically/71990 "2022-12-10T11:46:36Z")
**Showing post:** 6
### Author: ![hotNipi](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/hotnipi/32/383_2.png) [@hotNipi](https://discourse.nodered.org/u/hotNipi)
#### Post date: [10 December 2022 13:25 UTC](https://discourse.nodered.org/t/is-it-possible-to-tile-the-groups-in-node-red-dashboard-vertically/71990/6 "2022-12-10T13:25:17Z")
Well cant say it is impossible but many things then do need heavy overrides. So the layout behavior is completely different...
Smaller screen:
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/7/7/770bdf3b396f17b3dd28bcee5e010889536a8e6d.png)
Bigger screen
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/3/4/349c37112fa126df59b07c1f53364e1097fb587d.png)
Flow contains totally random nodes inside groups but all are from default collection.
[{"id":"1fb35f29bb459e80","type":"ui_button","z":"bf0d83d32eec75c2","name":"","group":"674712f8d915bcc0","order":9,"width":0,"height":0,"passthru":false,"label":"random","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"date","topic":"topic","topicType":"msg","x":180,"y":100,"wires":[[]]},{"id":"8ec4a283e5a7af92","type":"ui_button","z":"bf0d83d32eec75c2","name":"negative value","group":"674712f8d915bcc0","order":2,"width":3,"height":1,"passthru":true,"label":"- value","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"-5","payloadType":"num","topic":"","topicType":"str","x":200,"y":180,"wires":[[]]},{"id":"d5d8e1e3310fa854","type":"ui_button","z":"bf0d83d32eec75c2","name":"positive value","group":"674712f8d915bcc0","order":3,"width":3,"height":1,"passthru":true,"label":"+ value","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"3","payloadType":"num","topic":"","topicType":"str","x":200,"y":140,"wires":[[]]},{"id":"de6f6d0003c8f83c","type":"ui_template","z":"bf0d83d32eec75c2","group":"a0cb64ed7acda92f","name":"text-input","order":6,"width":"6","height":"1","format":"<style>\n /*the container class defined as additional class for ui_template*/\n .input-container{\n display: flex; \n flex-direction: row;\n justify-content: flex-start;\n align-items: center;\n padding:3px 12px;\n }\n /* a paragraph which is direct child of the input-container*/\n .input-container > p {\n color:red !important;\n user-select:none;\n width:100%;\n }\n /* an input element which is direct child of the input-container*/\n .input-container > input{\n background-color: transparent;\n border: unset;\n border-bottom: 1px solid #00a9ff; \n outline: unset;\n color: #e2ff00;\n text-align: end;\n width:3em;\n }\n\n \n</style>\n\n<p>HW Target temp</p>\n<input type=\"text\" min=\"17.2\" max=\"63\" ng-model=\"inputChange\" ng-keypress=\"$event.keyCode === 13 && sendInput()\"><span>°C</span></input>\n\n<script>\n(function(scope) {\n\n //define a variable to hold and share the typed data\n //so it can be used in any function in scope\n let inputData = ''\n\n // function to be called on keyboard \"Enter\"\n scope.sendInput = function() {\n //if the data is empty string, dont send anything \n if(inputData == ''){\n return\n } \n // send last know inputData to the server\n scope.send({payload: parseFloat(inputData), topic: \"input-changed\"}) \n }\n\n scope.$watch('inputChange', function(data) {\n if (data) { // every time something is typed, store the data so it can be used whenever needed\n inputData = data; \n }\n });\n // this can be deleted if you don't need to react on any input message.\n scope.$watch('msg', function(msg) {\n if (msg) {\n // Do something when msg arrives \n }\n });\n})(scope);\n</script>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"input-container","x":240,"y":220,"wires":[[]]},{"id":"ff30c601e53818e8","type":"ui_switch","z":"bf0d83d32eec75c2","name":"","label":"AC switch","tooltip":"","group":"a0cb64ed7acda92f","order":5,"width":"6","height":"1","passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":280,"y":260,"wires":[[]]},{"id":"b9039e34deee9b65","type":"ui_text","z":"bf0d83d32eec75c2","group":"674712f8d915bcc0","order":7,"width":0,"height":0,"name":"","label":"AC text","format":"value","layout":"row-spread","className":"","x":320,"y":300,"wires":[]},{"id":"9821976d.81e4a8","type":"inject","z":"bf0d83d32eec75c2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":500,"wires":[["5d17609.94dd2a","9d583201.b3e3","7ceb37db.bf6158","9f86e34f.b94b5"]]},{"id":"5d17609.94dd2a","type":"random","z":"bf0d83d32eec75c2","name":"","low":1,"high":"100","inte":"true","property":"payload","x":380,"y":460,"wires":[["ff079329.434ad"]]},{"id":"9d583201.b3e3","type":"random","z":"bf0d83d32eec75c2","name":"","low":1,"high":"100","inte":"true","property":"payload","x":380,"y":540,"wires":[["a8b35e60.cbf8b","6a797db2.668714"]]},{"id":"a8b35e60.cbf8b","type":"ui_template","z":"bf0d83d32eec75c2","group":"3cd020e88fa644c5","name":"simple level blue ","order":9,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n <div class=\"leveltext title\">LEVEL</div>\n <div class=\"leveltext value\"></div>\n <div class='levelbody' style='background:#2196f399;'></div>\n <div class='levelframe' style='border-color:#2196f3; border-width:2px;'></div>\n</div>\n<script>\n(function(scope) {\n \n scope.$watch('msg', function(msg) {\n if (msg) {\n if(!$(\"#level_\"+scope.$id)){\n return\n }\n $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"height\",msg.payload+\"%\")\n $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n }\n });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":600,"y":540,"wires":[[]]},{"id":"9139794a.12e668","type":"ui_template","z":"bf0d83d32eec75c2","group":"a0cb64ed7acda92f","name":"simple level top down","order":12,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n <div class=\"leveltext title\">BLINDS</div>\n <div class=\"leveltext value\"></div>\n <div class='levelbody topdown' style='background:\"#FFFFCCf7\";'></div>\n <div class='levelframe' style='border-color:\"#FFFFFF\"; border-width:6px;'></div>\n</div>\n\n<script>\n(function(scope) {\n \n scope.$watch('msg', function(msg) {\n if (msg) {\n if(!$(\"#level_\"+scope.$id)){\n return\n }\n $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"height\",msg.payload+\"%\")\n $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n }\n });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":620,"y":500,"wires":[[]]},{"id":"a78d7f3c.66fc6","type":"ui_template","z":"bf0d83d32eec75c2","group":"19f5ed07.08a453","name":"simple-gauge css","order":3,"width":0,"height":0,"format":"<style id=\"simple-gauge\">\n\n.simple-gauge{\n overflow:hidden;\n position:relative;\n width:100%;\n height:100%;\n}\n.levelbody.side.right {\n right:0;\n}\n.levelbody.side.left {\n left:0;\n}\n.levelbody.side {\n height:100%;\n width:0%;\n}\n.levelbody.topdown {\n bottom: unset;\n top:0;\n}\n.levelbody.round {\n height:100%;\n width:100%;\n}\n.levelbody{\n background: #FFFFCCf7;\n height: 0%;\n position: absolute;\n width: 100%;\n bottom: 0;\n z-index:0;\n transition: all 1s;\n box-shadow: inset 0px 0px 10px 0px #00000080;\n}\n.bodywrap{\n position: absolute;\n clip-path: circle(50%);\n width: 100%;\n height: 100%;\n bottom: 0;\n}\n.levelframe.round{\n border-radius:50%;\n}\n.levelframe{\n position:absolute;\n box-sizing:border-box;\n background:transparent;\n height:100%;\n width: 100%;\n border:1px solid #FFFFFF ;\n box-shadow:inset 0px 0px 41px 0px #000000b5;\n bottom:0;\n z-index:1;\n}\n.leveltext{\n top:30%;\n position:relative;\n width:100%;\n text-align:center;\n text-shadow: 0px 0px 9px #191938c2;\n z-index:2;\n mix-blend-mode: exclusion;\n}\n.leveltext.value{\n font-size:25px;\n}\n.leveltext.title{\n}\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":610,"y":620,"wires":[[]]},{"id":"ff079329.434ad","type":"ui_template","z":"bf0d83d32eec75c2","group":"19f5ed07.08a453","name":"simple level side","order":11,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n <div class=\"leveltext title\">BLINDS</div>\n <div class=\"leveltext value\"></div>\n <div class='levelbody side' style='background:\"#FFFFCCf7\";'></div>\n <div class='levelframe' style='border-color:\"#FFFFFF\"; border-width:6px;'></div>\n</div>\n\n<script>\n(function(scope) {\n \n scope.$watch('msg', function(msg) {\n if (msg) {\n if(!$(\"#level_\"+scope.$id)){\n return\n }\n $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"width\",msg.payload+\"%\")\n $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n }\n });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":600,"y":460,"wires":[[]]},{"id":"e9e664c6.c84b48","type":"ui_template","z":"bf0d83d32eec75c2","group":"19f5ed07.08a453","name":"simple level double side","order":13,"width":"4","height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n <div class=\"leveltext title\">CURTAINS</div>\n <div class=\"leveltext value\"></div>\n <div class='levelbody side left' style='background:\"#FFFFCCf7\";'></div>\n <div class='levelbody side right' style='background:\"#FFFFCCf7\";'></div>\n <div class='levelframe' style='border-color:\"#FFFFFF\"; border-width:6px;'></div>\n</div>\n\n<script>\n(function(scope) {\n \n scope.$watch('msg', function(msg) {\n if (msg) {\n if(!$(\"#level_\"+scope.$id)){\n return\n }\n $(\"#level_\"+scope.$id).find(\".levelbody.side\").css(\"width\",(msg.payload/2)+\"%\")\n \n $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n }\n });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":630,"y":420,"wires":[[]]},{"id":"6a797db2.668714","type":"ui_template","z":"bf0d83d32eec75c2","group":"3cd020e88fa644c5","name":"simple level blue round","order":10,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge round\">\n <div class=\"leveltext title\">LEVEL</div>\n <div class=\"leveltext value\"></div>\n <div class=bodywrap>\n <div class='levelbody round' style='background:#2196f399;'></div>\n </div>\n <div class='levelframe round' style='border-color:#2196f3; border-width:2px;'></div>\n</div>\n<script>\n(function(scope) {\n \n scope.$watch('msg', function(msg) {\n if (msg) {\n if(!$(\"#level_\"+scope.$id)){\n return\n }\n $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"top\",(100-msg.payload)+\"%\")\n $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n }\n });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":620,"y":580,"wires":[[]]},{"id":"9f86e34f.b94b5","type":"random","z":"bf0d83d32eec75c2","name":"","low":1,"high":"100","inte":"true","property":"payload","x":380,"y":420,"wires":[["e9e664c6.c84b48"]]},{"id":"7ceb37db.bf6158","type":"random","z":"bf0d83d32eec75c2","name":"","low":1,"high":"100","inte":"true","property":"payload","x":380,"y":500,"wires":[["9139794a.12e668"]]},{"id":"4e7e0d90ee7aa1ad","type":"ui_template","z":"bf0d83d32eec75c2","group":"674712f8d915bcc0","name":"A bit different layout","order":7,"width":0,"height":0,"format":"<style id='different-layout'>\n .masonry-container {\n position: relative;\n width:100%;\n margin: 1em auto;\n align-content: center;\n display: grid;\n grid: auto-flow / repeat(3, 330px);\n justify-content: center;\n justify-items: center;\n align-items: start;\n gap: 0.5em;\n }\n .masonry-container > * {\n position: relative;\n left:unset !important;\n top:unset!important; \n }\n\n .masonry-container > ui-card-panel:has(> .ordered-1){\n order:1;\n }\n .masonry-container > ui-card-panel:has(> .ordered-2){\n order:4;\n }\n .masonry-container > ui-card-panel:has(> .ordered-3){\n order:2;\n }\n .masonry-container > ui-card-panel:has(> .ordered-4){\n order:5;\n }\n .masonry-container > ui-card-panel:has(> .ordered-5){\n order:3;\n }\n .masonry-container > ui-card-panel:has(> .ordered-6){\n order:6;\n }\n\n @media screen and (max-width: 1024px) {\n .masonry-container {\n grid: auto-flow / repeat(2, 330px);\n }\n .masonry-container > ui-card-panel:has(> .ordered-1){\n order:1;\n }\n .masonry-container > ui-card-panel:has(> .ordered-2){\n order:3;\n }\n .masonry-container > ui-card-panel:has(> .ordered-3){\n order:5;\n }\n .masonry-container > ui-card-panel:has(> .ordered-4){\n order:2;\n }\n .masonry-container > ui-card-panel:has(> .ordered-5){\n order:4;\n }\n .masonry-container > ui-card-panel:has(> .ordered-6){\n order:6;\n }\n }\n\n\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":510,"y":220,"wires":[[]]},{"id":"7d38fc60032eac9c","type":"ui_numeric","z":"bf0d83d32eec75c2","name":"","label":"numeric","tooltip":"","group":"b5937d89450a68f6","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"topic","topicType":"msg","format":"{{value}}","min":0,"max":10,"step":1,"className":"","x":360,"y":340,"wires":[[]]},{"id":"64d74175c19852ce","type":"ui_switch","z":"bf0d83d32eec75c2","name":"","label":"switch","tooltip":"","group":"02e7165d30fe7c8f","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":410,"y":380,"wires":[[]]},{"id":"674712f8d915bcc0","type":"ui_group","name":"1. group","tab":"62083694d0eab7ca","order":1,"disp":true,"width":"6","collapse":true,"className":"ordered-1"},{"id":"a0cb64ed7acda92f","type":"ui_group","name":"3. group","tab":"62083694d0eab7ca","order":3,"disp":true,"width":"6","collapse":true,"className":"ordered-3"},{"id":"3cd020e88fa644c5","type":"ui_group","name":"4. group","tab":"62083694d0eab7ca","order":4,"disp":true,"width":"6","collapse":true,"className":"ordered-4"},{"id":"19f5ed07.08a453","type":"ui_group","name":"2. group","tab":"62083694d0eab7ca","order":2,"disp":true,"width":"6","collapse":true,"className":"ordered-2"},{"id":"b5937d89450a68f6","type":"ui_group","name":"5. group","tab":"62083694d0eab7ca","order":5,"disp":true,"width":"6","collapse":true,"className":"ordered-5"},{"id":"02e7165d30fe7c8f","type":"ui_group","name":"6. group","tab":"62083694d0eab7ca","order":6,"disp":true,"width":"6","collapse":true,"className":"ordered-6"},{"id":"62083694d0eab7ca","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
_[View the full topic](https://discourse.nodered.org/t/is-it-possible-to-tile-the-groups-in-node-red-dashboard-vertically/71990)._
