# Is there a nicer way to do this with UI\_Table
**URL:** https://discourse.nodered.org/t/is-there-a-nicer-way-to-do-this-with-ui-table/48155
**Category:** Dashboard
**Created:** [7 July 2021 23:40 UTC](https://discourse.nodered.org/t/is-there-a-nicer-way-to-do-this-with-ui-table/48155 "2021-07-07T23:40:05Z")
**Showing post:** 6
### Author: ![Christian-Me](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/christian-me/32/10774_2.png) [@Christian-Me](https://discourse.nodered.org/u/Christian-Me)
#### Post date: [8 July 2021 19:46 UTC](https://discourse.nodered.org/t/is-there-a-nicer-way-to-do-this-with-ui-table/48155/6 "2021-07-08T19:46:20Z")
Hi,
have you took `node-red-node-ui-table` (aka. Tabulator) into account. The data will have to be formatted slightly different and you will have to define a time formatted column (easy possible via `msg.ui_control`).
But in the end very versatile with possibility to graphically visualize your the price via a customized progress formatter, filtering sorting and a lot of other things
Let me know if you need any help with that.
msg.payload =[
        "Time":"13:01",
        "Price":17
        "Time":"13:06",
        "Price":24
        "Time":"13:11",
        "Price":15
        "Time":"13:16",
        "Price":16
        "Time":"13:21",
        "Price":16
        "Time":"13:26",
        "Price":18
> [@Ui-table supports ui\_control](https://discourse.nodered.org/t/ui-table-supports-ui-control/18870):
> Hello all, ui-table supports now sending msg.ui\_control messages to have more possibilities to style your dashboard table: or with grouping Example flow included but many other things should be possible. This Example is "generated" by data collected by my home automation system thermostat giving a compact overview of all values and settings with only one ui-node. Curious to see what you can do with it. Comments always welcome. Chris
_[View the full topic](https://discourse.nodered.org/t/is-there-a-nicer-way-to-do-this-with-ui-table/48155)._
