# It seems to be a bug in ui\_template node
**URL:** <https://discourse.nodered.org/t/it-seems-to-be-a-bug-in-ui-template-node/66941>\
**Created:** [26 August 2022 01:28 UTC](https://discourse.nodered.org/t/it-seems-to-be-a-bug-in-ui-template-node/66941 "2022-08-26T01:28:29Z")\
**Post date:** [26 August 2022 05:43 UTC](https://discourse.nodered.org/t/it-seems-to-be-a-bug-in-ui-template-node/66941/4 "2022-08-26T05:43:58Z")
It looks like you can produce it at will so create a small flow - maybe a couple infect nodes with the data and your ui-template node.
Once you verify it causes the error, export the flow and attach it to a response so someone can try to reproduce it.
````auto
   code goes here
Note: unfortunately it won’t be me since I’m at a location with no node-red available 😥
_[View the full topic](https://discourse.nodered.org/t/it-seems-to-be-a-bug-in-ui-template-node/66941)._
