# Limit access to Node-RED via client certificates
**URL:** <https://discourse.nodered.org/t/limit-access-to-node-red-via-client-certificates/83996>\
**Tags:** security\
**Created:** [23 December 2023 22:40 UTC](https://discourse.nodered.org/t/limit-access-to-node-red-via-client-certificates/83996 "2023-12-23T22:40:15Z")\
**Post date:** [24 December 2023 10:21 UTC](https://discourse.nodered.org/t/limit-access-to-node-red-via-client-certificates/83996/4 "2023-12-24T10:21:15Z")
> [@BartButenaers](#):
> What I liked more in your proposal, is the fact that you only have to make adjustements in your Node-RED server
I think my aim for it, is to allow the inexperienced users to have a barrier without trying to understand the various products / services that are around.
It's been updated and now uses a built in class to help add the IP Address', Ranges & Subnets.
example:
const allowedIPs = [
  "127.0.0.1", /* Localhost */
  "172.16.0.0/24", /* Private Network */
  "103.22.200.1-103.22.203.254" /* CloudFlare range example */
Taking out the hosted services from the equation, both the client cert and IP White listing approach are both extremely powerful mechanisms! 🤓
Note: I added the the **security** tag to this post
_[View the full topic](https://discourse.nodered.org/t/limit-access-to-node-red-via-client-certificates/83996)._
