# Looking for a GUI to define Input for Schedex
**URL:** https://discourse.nodered.org/t/looking-for-a-gui-to-define-input-for-schedex/8938
**Category:** Dashboard
**Created:** [13 March 2019 19:11 UTC](https://discourse.nodered.org/t/looking-for-a-gui-to-define-input-for-schedex/8938 "2019-03-13T19:11:56Z")
**Showing post:** 16
### Author: ![drmibell](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/drmibell/32/8424_2.png) [@drmibell](https://discourse.nodered.org/u/drmibell)
#### Post date: [11 January 2020 00:28 UTC](https://discourse.nodered.org/t/looking-for-a-gui-to-define-input-for-schedex/8938/16 "2020-01-11T00:28:30Z")
This flow provides a dashboard UI for programming `schedex` nodes. The project turned out to be a bit more challenging than I expected, and the result has some kludgy bits and probably bugs. (You've been warned.)
[{"id":"2f7c2f6d.c20a68","type":"tab","label":"Programming","disabled":false,"info":""},{"id":"b888aaf7.fdcdb8","type":"tab","label":"Timers","disabled":false,"info":"For testing, the timers should be configured as:\n- Timer1: `{\nontime: \"07:00\"\nontopic: \"timer1on\"\nonpayload: \"on\"\n onoffset: \"200\"\n onrandomoffset: true\n offtime: \"08:00\"\n offtopic: \"timer1off\"\n offpayload: \"off\"\n offoffset: 0\n offrandomoffset: false\n mon: true\n tue: true\n wed: true\n thu: true\n fri: true\n sat: true\n sun: true\n lon: \"-1.4\"\n lat: \"51.025\"\n suspended: false\n name: \"timer1\"\n}`\n- Timer2: `{\nontime: \"09:00\"\nontopic: \"timer2on\"\nonpayload: \"1\"\nonoffset: 0\nonrandomoffset: false\nofftime: \"10:00\"\nofftopic: \"timer2off\"\noffpayload: \"0\"\noffoffset: \"100\"\noffrandomoffset: true\nmon: false\ntue: false\nwed: false\nthu: false\nfri: false\nsat: true\nsun: true\nlon: \"\"\nlat: \"\"\nsuspended: false\nname: \"timer2\"\n}`\n- Timer3: `{\nontime: \"11:00\"\nontopic: \"timer3on\"\nonpayload: \"true\"\nonoffset: 0\nonrandomoffset: false\nofftime: \"12:00\"\nofftopic: \"timer3off\"\noffpayload: \"false\"\noffoffset: 0\noffrandomoffset: false\nmon: true\ntue: true\nwed: true\nthu: true\nfri: true\nsat: false\nsun: false\nlon: \"-1.4\"\nlat: \"51.025\"\nsuspended: false\nname: \"timer3\"\n}`\n- Timer4: `{\nontime: \"13:00\"\nontopic: \"timer4on\"\nonpayload: \"on\"\nonoffset: \"10\"\nonrandomoffset: true\nofftime: \"14:00\"\nofftopic: \"timer4off\"\noffpayload: \"off\"\noffoffset: \"20\"\noffrandomoffset: true\nmon: true\ntue: false\nwed: true\nthu: false\nfri: true\nsat: false\nsun: false\nlon: \"-1.4\"\nlat: \"51.025\"\nsuspended: true\nname: \"timer4\"\n}`\n"},{"id":"1070b5a9.049e52","type":"tab","label":"Dashboard","disabled":false,"info":""},{"id":"67db763a.31161","type":"ui_base","theme":{"name":"theme-dark","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#097479","value":"#097479","edited":false},"page-titlebar-backgroundColor":{"value":"#097479","edited":false},"page-backgroundColor":{"value":"#111111","edited":false},"page-sidebar-backgroundColor":{"value":"#000000","edited":false},"group-textColor":{"value":"#0eb8c0","edited":false},"group-borderColor":{"value":"#555555","edited":false},"group-backgroundColor":{"value":"#333333","edited":false},"widget-textColor":{"value":"#eeeeee","edited":false},"widget-backgroundColor":{"value":"#097479","edited":false},"widget-borderColor":{"value":"#333333","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"36c9c21a.96173e","type":"ui_group","z":"","name":"Timer Program","tab":"73d76463.0a02dc","order":1,"disp":true,"width":8,"collapse":false},{"id":"74f33e54.c2d83","type":"ui_spacer","name":"spacer","group":"70335fb2.428898","order":4,"width":3,"height":1},{"id":"73d76463.0a02dc","type":"ui_tab","z":"","name":"schedex node programming","icon":"dashboard","disabled":false,"hidden":false},{"id":"dd827103.f06e2","type":"ui_spacer","name":"spacer","group":"36c9c21a.96173e","order":3,"width":1,"height":1},{"id":"8efd2d7.c73075","type":"ui_spacer","name":"spacer","group":"36c9c21a.96173e","order":19,"width":1,"height":1},{"id":"cc4da946.96b3f8","type":"ui_spacer","name":"spacer","group":"36c9c21a.96173e","order":7,"width":1,"height":1},{"id":"d00d3eab.92f5b8","type":"ui_spacer","name":"spacer","group":"36c9c21a.96173e","order":11,"width":1,"height":1},{"id":"b5501232.2fff9","type":"schedex","z":"b888aaf7.fdcdb8","name":"timer1","suspended":false,"lat":"51.025","lon":"-1.4","ontime":"07:00","ontopic":"timer1on","onpayload":"on","onoffset":"200","onrandomoffset":true,"offtime":"08:00","offtopic":"timer1off","offpayload":"off","offoffset":0,"offrandomoffset":false,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"sun":true,"x":510,"y":100,"wires":[[]]},{"id":"7ffaec7f.b94304","type":"schedex","z":"b888aaf7.fdcdb8","name":"timer2","suspended":false,"lat":"","lon":"","ontime":"09:00","ontopic":"timer2on","onpayload":"1","onoffset":0,"onrandomoffset":false,"offtime":"10:00","offtopic":"timer2off","offpayload":"0","offoffset":"100","offrandomoffset":true,"mon":false,"tue":false,"wed":false,"thu":false,"fri":false,"sat":true,"sun":true,"x":510,"y":160,"wires":[[]]},{"id":"bfc793b2.ca5ac","type":"schedex","z":"b888aaf7.fdcdb8","name":"timer3","suspended":false,"lat":"51.025","lon":"-1.4","ontime":"11:00","ontopic":"timer3on","onpayload":"true","onoffset":0,"onrandomoffset":false,"offtime":"12:00","offtopic":"timer3off","offpayload":"false","offoffset":0,"offrandomoffset":false,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":false,"sun":false,"x":510,"y":220,"wires":[[]]},{"id":"5b6e102f.6fe1","type":"schedex","z":"b888aaf7.fdcdb8","name":"timer4","suspended":true,"lat":"51.025","lon":"-1.4","ontime":"13:00","ontopic":"timer4on","onpayload":"on","onoffset":"10","onrandomoffset":true,"offtime":"14:00","offtopic":"timer4off","offpayload":"off","offoffset":"20","offrandomoffset":true,"mon":true,"tue":false,"wed":true,"thu":false,"fri":true,"sat":false,"sun":false,"x":510,"y":280,"wires":[["43374b26.800b8c"]]},{"id":"6da5cb4b.a8d624","type":"inject","z":"2f7c2f6d.c20a68","name":"startup","topic":"startup","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"0","x":280,"y":80,"wires":[["3fd2fdab.c9316a"]]},{"id":"3fd2fdab.c9316a","type":"http request","z":"2f7c2f6d.c20a68","name":"GET flows","method":"GET","ret":"obj","paytoqs":false,"url":"http://localhost:1880/flows","tls":"","persist":false,"proxy":"","authType":"basic","x":450,"y":100,"wires":[["69061920.be04e"]],"info":"Get list (array) of all tabs and nodes.\n"},{"id":"31f9e070.867d48","type":"ui_button","z":"2f7c2f6d.c20a68","name":"","group":"36c9c21a.96173e","order":25,"width":2,"height":1,"passthru":true,"label":"enter","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":290,"y":340,"wires":[["eff8af.4fbda75"]]},{"id":"e628595a.519808","type":"ui_button","z":"2f7c2f6d.c20a68","name":"","group":"36c9c21a.96173e","order":26,"width":3,"height":1,"passthru":true,"label":"cancel","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":290,"y":300,"wires":[["829ffd9d.34944"]]},{"id":"fcd4dc4f.39cf7","type":"link out","z":"2f7c2f6d.c20a68","name":"dashboard","links":["3483a1c7.e219be","3ec86e62.f2149a","ba57316.2a653d","c361c25b.5ffb4","e548d302.4e9298","50f68ec5.b21388","ee76c4f1.c1a97","2ce14e8.d6aad32","a1cfd4ee.fdd4e"],"x":650,"y":240,"wires":[],"l":true},{"id":"823a00d6.767448","type":"ui_button","z":"2f7c2f6d.c20a68","name":"","group":"36c9c21a.96173e","order":24,"width":3,"height":1,"passthru":true,"label":"reset","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"reset","x":290,"y":120,"wires":[["3fd2fdab.c9316a"]]},{"id":"2f6357db.bcb44","type":"inject","z":"2f7c2f6d.c20a68","name":"cancel","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":300,"wires":[["e628595a.519808"]]},{"id":"ba040dde.294888","type":"inject","z":"2f7c2f6d.c20a68","name":"enter","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":340,"wires":[["31f9e070.867d48"]]},{"id":"75acb159.4d8a4","type":"inject","z":"2f7c2f6d.c20a68","name":"reset","topic":"reset","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":120,"wires":[["823a00d6.767448"]]},{"id":"25522a14.5997a6","type":"function","z":"2f7c2f6d.c20a68","name":"reset","func":"const i = global.get('selection');\nmsg.select = true;\nmsg.topic = global.get('timers')[i];\nvar nodes = msg.payload.filter(findNodes); // array of schedex nodes\nnodes.sort(function(a,b){return a.name > b.name}); // sort by name\n// no cleanup this time\nvar program = global.get('program'); // reset program\nprogram[i] = nodes[i];\nglobal.set('program',program);\nmsg.payload = program[i];\nreturn msg;\n\nfunction findNodes(x){\n return x.type === \"schedex\"\n}\n","outputs":1,"noerr":0,"x":330,"y":240,"wires":[["fcd4dc4f.39cf7","b92536a0.404088"]]},{"id":"92907703.dd218","type":"switch","z":"b888aaf7.fdcdb8","name":"timer1","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"timer1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":60,"wires":[["b5501232.2fff9"]]},{"id":"c7125ca4.33c6e","type":"link in","z":"b888aaf7.fdcdb8","name":"","links":["b92536a0.404088"],"x":275,"y":60,"wires":[["92907703.dd218"]]},{"id":"b92536a0.404088","type":"link out","z":"2f7c2f6d.c20a68","name":"timers","links":["1fca179d.ff2eb8","5f95bbab.f701f4","b9feae4f.515388","c7125ca4.33c6e","dd004900.275c08","33d1654c.49ef1a"],"x":630,"y":280,"wires":[],"l":true},{"id":"fdfbd4ad.2b802","type":"switch","z":"b888aaf7.fdcdb8","name":"timer2","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"timer2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":120,"wires":[["7ffaec7f.b94304"]]},{"id":"dd004900.275c08","type":"link in","z":"b888aaf7.fdcdb8","name":"","links":["b92536a0.404088"],"x":275,"y":120,"wires":[["fdfbd4ad.2b802"]]},{"id":"37a90171.0b70fe","type":"switch","z":"b888aaf7.fdcdb8","name":"timer3","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"timer3","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":180,"wires":[["bfc793b2.ca5ac"]]},{"id":"1fca179d.ff2eb8","type":"link in","z":"b888aaf7.fdcdb8","name":"","links":["b92536a0.404088"],"x":275,"y":180,"wires":[["37a90171.0b70fe"]]},{"id":"56397dd.8133704","type":"switch","z":"b888aaf7.fdcdb8","name":"timer4","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"timer4","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":240,"wires":[["5b6e102f.6fe1"]]},{"id":"5f95bbab.f701f4","type":"link in","z":"b888aaf7.fdcdb8","name":"","links":["b92536a0.404088"],"x":275,"y":240,"wires":[["56397dd.8133704"]]},{"id":"59e8b2d6.cbbd0c","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"F","tooltip":"","group":"36c9c21a.96173e","order":16,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"fri","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":650,"y":660,"wires":[["38214638.d15062"]]},{"id":"757b6407.93bfac","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"Sa","tooltip":"","group":"36c9c21a.96173e","order":17,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"sat","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":710,"y":700,"wires":[["38214638.d15062"]]},{"id":"26165084.cac6","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"Su","tooltip":"","group":"36c9c21a.96173e","order":18,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"sun","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":750,"y":740,"wires":[["38214638.d15062"]]},{"id":"632c7f85.3c1a7","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"M","tooltip":"","group":"36c9c21a.96173e","order":12,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"mon","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":490,"y":500,"wires":[["38214638.d15062"]]},{"id":"ff572887.7ad76","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"Tu","tooltip":"","group":"36c9c21a.96173e","order":13,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"tue","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":530,"y":540,"wires":[["38214638.d15062"]]},{"id":"78babdf4.24f33c","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"W","tooltip":"","group":"36c9c21a.96173e","order":14,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"wed","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":570,"y":580,"wires":[["38214638.d15062"]]},{"id":"ae78308b.1b4898","type":"ui_switch","z":"1070b5a9.049e52","name":"","label":"Th","tooltip":"","group":"36c9c21a.96173e","order":15,"width":"1","height":1,"passthru":true,"decouple":"false","topic":"thu","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":610,"y":620,"wires":[["38214638.d15062"]]},{"id":"3483a1c7.e219be","type":"link in","z":"1070b5a9.049e52","name":"program","links":["d25d866c.8a0408","fe18f21a.ceb84","d67a4762.fe9ad8","1a0d9394.7a11a4","fcd4dc4f.39cf7","a70fb0b3.eb4cd"],"x":160,"y":540,"wires":[["aa8b0026.128e3","a98bbbb3.5d96d","4bd44087.5a2338","a8c1557b.980cb8","4de4e61d.3eddc8","3b1817b7.ed688","5b74cf5c.c0e2d","f0fc11f4.d9f028","d93e6493.7d9448","56665016.eed738"]],"l":true},{"id":"dc56cfd3.d7f388","type":"ui_text_input","z":"1070b5a9.049e52","name":"on time","label":"On time","tooltip":"","group":"36c9c21a.96173e","order":4,"width":"3","height":1,"passthru":false,"mode":"text","delay":"300","topic":"ontime","x":520,"y":40,"wires":[["4841a765.6a20c8"]]},{"id":"c4c22f3b.f4ee5","type":"change","z":"1070b5a9.049e52","name":"ontime","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.ontime","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":40,"wires":[["dc56cfd3.d7f388"]]},{"id":"c361c25b.5ffb4","type":"link in","z":"1070b5a9.049e52","name":"program","links":["fcd4dc4f.39cf7"],"x":160,"y":180,"wires":[["c4c22f3b.f4ee5","f5e3f327.3112a8","687a8e68.6deec","155795ba.49b2a2","feef6961.5abd1","628a9f6d.54b678","23823687.ab3e9a","bd123285.a95848"]],"l":true},{"id":"f5e3f327.3112a8","type":"change","z":"1070b5a9.049e52","name":" onoffset","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.onoffset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":80,"wires":[["bb3f3cde.0f6c98"]]},{"id":"bb3f3cde.0f6c98","type":"ui_text_input","z":"1070b5a9.049e52","name":"on offset","label":"Offset (min)","tooltip":"","group":"36c9c21a.96173e","order":5,"width":"2","height":1,"passthru":false,"mode":"text","delay":"300","topic":"onoffset","x":520,"y":80,"wires":[["4841a765.6a20c8"]]},{"id":"687a8e68.6deec","type":"change","z":"1070b5a9.049e52","name":"offtime","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.offtime","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":120,"wires":[["b7c05bf9.c0f45"]]},{"id":"b7c05bf9.c0f45","type":"ui_text_input","z":"1070b5a9.049e52","name":"off time","label":"Off time","tooltip":"","group":"36c9c21a.96173e","order":8,"width":3,"height":1,"passthru":false,"mode":"text","delay":300,"topic":"offtime","x":520,"y":120,"wires":[["4841a765.6a20c8"]]},{"id":"155795ba.49b2a2","type":"change","z":"1070b5a9.049e52","name":"offoffset","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.offoffset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":160,"wires":[["5dadc79b.d70188"]]},{"id":"5dadc79b.d70188","type":"ui_text_input","z":"1070b5a9.049e52","name":"off offset","label":"Offset (min)","tooltip":"","group":"36c9c21a.96173e","order":9,"width":"2","height":1,"passthru":false,"mode":"text","delay":300,"topic":"offoffset","x":520,"y":160,"wires":[["4841a765.6a20c8"]]},{"id":"a26821d1.c67928","type":"ui_switch","z":"1070b5a9.049e52","name":"on random offset","label":"Random","tooltip":"","group":"36c9c21a.96173e","order":6,"width":2,"height":1,"passthru":true,"decouple":"false","topic":"onrandomoffset","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":590,"y":420,"wires":[["38214638.d15062"]]},{"id":"7583bddb.0a3cd4","type":"ui_switch","z":"1070b5a9.049e52","name":"off random offset","label":"Random","tooltip":"","group":"36c9c21a.96173e","order":10,"width":2,"height":1,"passthru":true,"decouple":"false","topic":"offrandomoffset","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":630,"y":460,"wires":[["38214638.d15062"]]},{"id":"aa8b0026.128e3","type":"change","z":"1070b5a9.049e52","name":"mon","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.mon","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":500,"wires":[["632c7f85.3c1a7"]]},{"id":"a98bbbb3.5d96d","type":"change","z":"1070b5a9.049e52","name":"tue","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.tue","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":540,"wires":[["ff572887.7ad76"]]},{"id":"5b74cf5c.c0e2d","type":"change","z":"1070b5a9.049e52","name":"sun","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.sun","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":740,"wires":[["26165084.cac6"]]},{"id":"4de4e61d.3eddc8","type":"change","z":"1070b5a9.049e52","name":"fri","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.fri","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":660,"wires":[["59e8b2d6.cbbd0c"]]},{"id":"a8c1557b.980cb8","type":"change","z":"1070b5a9.049e52","name":"thu","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.thu","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":620,"wires":[["ae78308b.1b4898"]]},{"id":"4bd44087.5a2338","type":"change","z":"1070b5a9.049e52","name":"wed","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.wed","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":580,"wires":[["78babdf4.24f33c"]]},{"id":"3b1817b7.ed688","type":"change","z":"1070b5a9.049e52","name":"sat","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.sat","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":700,"wires":[["757b6407.93bfac"]]},{"id":"f0fc11f4.d9f028","type":"change","z":"1070b5a9.049e52","name":" offrandom","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.offrandomoffset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":460,"wires":[["7583bddb.0a3cd4"]]},{"id":"d93e6493.7d9448","type":"change","z":"1070b5a9.049e52","name":" onrandom","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.onrandomoffset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":420,"wires":[["a26821d1.c67928"]]},{"id":"3e4eef12.1c9e8","type":"ui_switch","z":"1070b5a9.049e52","name":"suspended","label":"Suspended","tooltip":"","group":"36c9c21a.96173e","order":2,"width":2,"height":1,"passthru":true,"decouple":"false","topic":"suspended","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-check-square-o","oncolor":"--nr-dashboard-widgetTextColor","offvalue":"false","offvalueType":"bool","officon":"fa-square-o","offcolor":"--nr-dashboard-widgetTextColor","x":530,"y":380,"wires":[["38214638.d15062"]]},{"id":"56665016.eed738","type":"change","z":"1070b5a9.049e52","name":"suspended","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.suspended","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":380,"wires":[["3e4eef12.1c9e8"]]},{"id":"c091824d.9ef168","type":"ui_text_input","z":"1070b5a9.049e52","name":"","label":"On topic","tooltip":"","group":"36c9c21a.96173e","order":20,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"ontopic","x":520,"y":200,"wires":[["4841a765.6a20c8"]]},{"id":"33a5546f.a5b7d4","type":"ui_text_input","z":"1070b5a9.049e52","name":"","label":"Off topic","tooltip":"","group":"36c9c21a.96173e","order":22,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"offtopic","x":520,"y":280,"wires":[["4841a765.6a20c8"]]},{"id":"7cabe1a1.4a7008","type":"ui_text_input","z":"1070b5a9.049e52","name":"","label":"On payload","tooltip":"","group":"36c9c21a.96173e","order":21,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"onpayload","x":530,"y":240,"wires":[["4841a765.6a20c8"]]},{"id":"118502f7.62b7ed","type":"ui_text_input","z":"1070b5a9.049e52","name":"","label":"Off payload","tooltip":"","group":"36c9c21a.96173e","order":23,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"offpayload","x":530,"y":320,"wires":[["4841a765.6a20c8"]]},{"id":"feef6961.5abd1","type":"change","z":"1070b5a9.049e52","name":"ontopic","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.ontopic","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":359,"y":200,"wires":[["c091824d.9ef168"]]},{"id":"628a9f6d.54b678","type":"change","z":"1070b5a9.049e52","name":"onpayload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.onpayload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":369,"y":240,"wires":[["7cabe1a1.4a7008"]]},{"id":"23823687.ab3e9a","type":"change","z":"1070b5a9.049e52","name":"ontopic","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.offtopic","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":359,"y":280,"wires":[["33a5546f.a5b7d4"]]},{"id":"bd123285.a95848","type":"change","z":"1070b5a9.049e52","name":"offpayload","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.offpayload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":369,"y":320,"wires":[["118502f7.62b7ed"]]},{"id":"8bee0df8.9a3d78","type":"ui_dropdown","z":"2f7c2f6d.c20a68","name":"select","label":"Select","tooltip":"","place":"Select timer","group":"36c9c21a.96173e","order":1,"width":5,"height":1,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"select","x":490,"y":180,"wires":[["4149b917.eca6"]]},{"id":"b61417ef.9bdf98","type":"function","z":"2f7c2f6d.c20a68","name":"initialize","func":"var timers = []; \nvar program = []; \nglobal.set('update',{});\nvar nodes = msg.payload.filter(findNodes); // array of schedex nodes\nnodes.sort(function(a,b){return a.name > b.name}); // sort by name\nfor (i=0;i<nodes.length;i++){\n name = nodes[i].name; // check for duplicates\n if (timers.includes(name)) {\n node.error(\"Duplicate node names\");\n return;\n }\n if (name !== '') { // skip blank names\n timers.push(name);\n delete nodes[i].id; // for neatness, probably not needed\n delete nodes[i].type\n delete nodes[i].z\n delete nodes[i].x;\n delete nodes[i].y;\n delete nodes[i].wires;\n }\n}\nglobal.set('program',nodes);\nglobal.set(\"timers\",timers);\n\n// initialize timers\nfor (i=0;i<nodes.length;i++){\n msg.topic = timers[i];\n msg.payload = nodes[i];\n \n node.send([null,msg]);\n}\n\n// initialize dashboard\nmsg.options = timers; // initialize ui_dropdown menu\nglobal.set('selection',0); // set default selection\nmsg.payload = timers[0];\nreturn [msg,null];\n\nfunction findNodes(x){\n return x.type === \"schedex\"\n}\n","outputs":2,"noerr":0,"x":340,"y":200,"wires":[["8bee0df8.9a3d78"],["b92536a0.404088"]],"info":"- Get list (array) of `schedex` nodes.\n- Set up dropdown menu.\n- Set initial selection to `timer[0]`\n"},{"id":"829ffd9d.34944","type":"function","z":"2f7c2f6d.c20a68","name":"cancel","func":"const i = global.get('selection');\nglobal.set('update',{});\nmsg.select = true;\nmsg.topic = global.get('timers')[i];\nmsg.payload = global.get('program')[i];\nreturn msg;","outputs":1,"noerr":0,"x":410,"y":300,"wires":[["fcd4dc4f.39cf7"]]},{"id":"eff8af.4fbda75","type":"function","z":"2f7c2f6d.c20a68","name":"enter","func":"var i = global.get('selection');\nvar program = global.get('program');\nvar update = global.get('update');\nfor (let x in update) {\n program[i][x] = update[x];\n}\nglobal.set('program',program);\nglobal.set('update',{});\nmsg.topic = global.get('timers')[i];\nmsg.payload = program[i];\nreturn msg;","outputs":1,"noerr":0,"x":410,"y":340,"wires":[["b92536a0.404088"]]},{"id":"38214638.d15062","type":"function","z":"1070b5a9.049e52","name":"booleans","func":"if (msg.select) {\n global.set('update',{});\n} else {\n update = global.get('update') || {};\n node.warn(msg.topic);\n let property = msg.topic;\n update[property] = msg.payload;\n global.set('update',update);\n node.warn(update);\n}\nreturn msg","outputs":0,"noerr":0,"x":820,"y":540,"wires":[]},{"id":"4149b917.eca6","type":"function","z":"2f7c2f6d.c20a68","name":"show","func":"var timers = global.get(\"timers\");\nvar i = timers.indexOf(msg.payload);\nglobal.set('selection',i);\nvar program = global.get(\"program\");\nglobal.set('update',{});\nmsg = {'payload':program[i]};\nmsg.select = true;\nreturn msg;","outputs":1,"noerr":0,"x":610,"y":180,"wires":[["fcd4dc4f.39cf7"]],"outputLabels":["timers"]},{"id":"4841a765.6a20c8","type":"function","z":"1070b5a9.049e52","name":"strings","func":"update = global.get('update') || {};\nnode.warn(msg.topic);\nlet property = msg.topic;\nupdate[property] = msg.payload;\nglobal.set('update',update);\nreturn msg","outputs":0,"noerr":0,"x":710,"y":180,"wires":[]},{"id":"69061920.be04e","type":"switch","z":"2f7c2f6d.c20a68","name":"action","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"startup","vt":"str"},{"t":"eq","v":"reset","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":190,"y":220,"wires":[["b61417ef.9bdf98"],["25522a14.5997a6"]],"info":"Select startup or reset action."},{"id":"d260d894.c43d7","type":"inject","z":"b888aaf7.fdcdb8","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":280,"wires":[["5b6e102f.6fe1"]]},{"id":"3ec6b734.70852","type":"inject","z":"b888aaf7.fdcdb8","name":"","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":320,"wires":[["5b6e102f.6fe1"]]},{"id":"c28ea6e6.a354d","type":"inject","z":"b888aaf7.fdcdb8","name":"","topic":"","payload":"toggle","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":360,"wires":[["5b6e102f.6fe1"]]},{"id":"abc40a68.94aa","type":"inject","z":"b888aaf7.fdcdb8","name":"","topic":"","payload":"info","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":400,"wires":[["5b6e102f.6fe1"]]},{"id":"43374b26.800b8c","type":"debug","z":"b888aaf7.fdcdb8","name":"timer4 output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":660,"y":280,"wires":[]}]
The dashboard looks like this.
 ![Timer_Program](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/9/d/9d56efd87beb37e6ae14c8bbee1c9193af8cf4b9.jpeg)
Changes can be entered in the text fields and checkboxes, which correspond to the settings in the node's edit dialog. At present, there are no checks for valid input, so caution is required. The dropdown menu lets the user choose which `schedex` node to program. The `cancel` button discards any changes, and the `enter` button writes them into the selected node. The `reset` button restores the node parameters to the values in the edit dialog. Selecting a different node discards any changes that have not been entered.
At startup, the flow scans the flow file for instances of the `schedex` node and identifies them by the `name` property. Each instance must have a unique name, except that unnamed nodes are ignored. To use the interface, a `schedex` node may be located anywhere in the flow but must have its input connected to the programmer through a `link in` node and a `switch` node programmed to pass only messages with `msg.topic` equal to the node name. Other inputs and outputs are connected as usual. This is shown in the `Timers` tab, which has an example consisting of four `schedex` nodes.
I have no idea whether anyone will find this useful, but I have learned a bit while developing it and will be happy to fix bugs or make improvements if they are brought to my attention.
_[View the full topic](https://discourse.nodered.org/t/looking-for-a-gui-to-define-input-for-schedex/8938)._
