# Manual Node Install Dietpi
**URL:** https://discourse.nodered.org/t/manual-node-install-dietpi/72682
**Category:** General
**Created:** [25 December 2022 12:38 UTC](https://discourse.nodered.org/t/manual-node-install-dietpi/72682 "2022-12-25T12:38:15Z")
**Showing post:** 3
### Author: ![Ianszh](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/ianszh/32/8897_2.png) [@Ianszh](https://discourse.nodered.org/u/Ianszh)
#### Post date: [26 December 2022 15:17 UTC](https://discourse.nodered.org/t/manual-node-install-dietpi/72682/3 "2022-12-26T15:17:07Z")
On this [Github page](https://github.com/gablau/node-red-contrib-blynk-iot) where I got the npm from it doesn't actually say where it just says "If you installed Node Red globally use this command to install `npm install --global node-red-contrib-blynk-iot`"
And as I'm running a RPi with DietPi I followed the advice from a post [here](https://discourse.nodered.org/t/dietpi-node-red-folder-does-not-exist/52405/4?) on the discourse, which states as above to install in `/mnt/dietpi_userdata/node-red`. which I did and there is no trace of anything having been installed.
_[View the full topic](https://discourse.nodered.org/t/manual-node-install-dietpi/72682)._
