Migrating ui template from Dashboard-1 to Dashboard-2
Hallo Walter,
danke für deine ausführliche Antwort.
I ve found the option to change the size and the sound. Thanx!
Lags are still there I will try to fix them. This is the first node / way making RTSP get to work since mp4frag is not ported to DB 2.0. A good start.
Hello WhiteLion
I have been reading along with great interest, as I would also like to see my rstp cameras on the dashboard.
Unfortunately I am failing. Everything works with the RedBull video.
But I'm making a mistake somewhere with my cameras. What exactly do I need to change?
Maybe you can share your flow?
Best regards
Manuwa
I ve no problem sharing my flow but I am sure you would be frustrated because it hangs on many subflows. (At the image above your post you can see the "payload2action" function node) The variables in that node are cobbled together to build the vars for the following nodes. And the other thing is: there is mostly Dashboard 1 stuff inside..... The migration for dashboard 2.0 is not working like it should (stream shuttering every 5 seconds)... I ve no solution for that as for the cam-sound which is only available when editing stuff in the template..... I ve no good solution for my cams for DB 2.0 and did not see anybody having it :frowning:
I will wait and not implement it and can not recommend this (at least not with my reolink cams).
To try it out then don t mess around with my stuff its a modified copy of what krambriw did. His flow -> HERE will give you a better start then my stuff:
Thank you very much for your assessment.
Then I will stick with just displaying snapshots for the time being and will continue to test and try.
If you come closer to a good solution, I would be happy if you let me, or us, know.
Thanks again!
Manuwa
