# MinIO Instance Configuration
**URL:** https://discourse.nodered.org/t/minio-instance-configuration/82306
**Category:** Developing Nodes
**Created:** [24 October 2023 14:47 UTC](https://discourse.nodered.org/t/minio-instance-configuration/82306 "2023-10-24T14:47:13Z")
### Author: ![marcus-j-davies](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/marcus-j-davies/32/103435_2.png) [@marcus-j-davies](https://discourse.nodered.org/u/marcus-j-davies)
#### Post date: [24 October 2023 16:11 UTC](https://discourse.nodered.org/t/minio-instance-configuration/82306/2 "2023-10-24T16:11:30Z")
1. Moved to **General** - as I do not believe you are **Developing Nodes**
2. I quote from the read me
> **Please Note:** This set of nodes (and associated support information) is a work in progress.
1. We have seen this node in the forums before, the Node does not appear to be maintained
[Error with Minio Notification - #3 by zenofmud](https://discourse.nodered.org/t/error-with-minio-notification/82155/3)
My suggestion is to try and reach out to the dev, and if you don't get a response, search for a better node.
_[View the full topic](https://discourse.nodered.org/t/minio-instance-configuration/82306)._
