No, it is not.
The help states:
send boolean
trueinmsg.connectormsg.disconnect
you have set disconnect to false! It should be true
Please try to read the information provided carefully & double check everything.
No, it is not.
The help states:
send boolean
@Steve-Mcl
I did it and it worked but now the problem still there when i run 1 thing and i monitor it for a day in between it goes not connected but one thing it need to know is that when it shows not connected it does not give any output to debug node as i used the example above with corrected data i just want to know that is there any solution for this if i am not there and suddenly if it goes to not connected
As i suggested before, you can use a status node.
But, it should be more reliable - perhaps you are pushing it to hard - perhaps every 1 sec is too quick and you are causing backpresure.
I would measure how long it takes from inject to final result. You can do this by setting a context variable to the timestamp at the start & one at the end then calculate the difference.
I would probably also set a context flag from the status node to inhibit polling when it is not connected.
@Steve-Mcl
I still did not understand what you told here
That is basic node-red stuff. I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
@Steve-Mcl
Why it shows me Red Light
I cannot help with that - try a PLC forum or contact Mitsubishi.
