# Modbus/Arrays extract divide and give in stream
**URL:** <https://discourse.nodered.org/t/modbus-arrays-extract-divide-and-give-in-stream/8772>\
**Created:** [9 March 2019 11:27 UTC](https://discourse.nodered.org/t/modbus-arrays-extract-divide-and-give-in-stream/8772 "2019-03-09T11:27:43Z")\
**Post date:** [9 March 2019 14:03 UTC](https://discourse.nodered.org/t/modbus-arrays-extract-divide-and-give-in-stream/8772/4 "2019-03-09T14:03:43Z")
Did you realise you have posted a flow containing just a debug node and nothing else?
See here for how to post a flow in this forum.
_[View the full topic](https://discourse.nodered.org/t/modbus-arrays-extract-divide-and-give-in-stream/8772)._
