# Modbus Read Node via Modbus TCP in Node Red
**URL:** <https://discourse.nodered.org/t/modbus-read-node-via-modbus-tcp-in-node-red/101365>\
**Tags:** modbus\
**Created:** [27 June 2026 01:36 UTC](https://discourse.nodered.org/t/modbus-read-node-via-modbus-tcp-in-node-red/101365 "2026-06-27T01:36:34Z")\
**Showing post:** 16
**Post date:** [28 June 2026 10:23 UTC](https://discourse.nodered.org/t/modbus-read-node-via-modbus-tcp-in-node-red/101365/16 "2026-06-28T10:23:41Z")
Select the nodes that you showed the image of earlier, plus the Trigger node, then hit CTRL+E and click Export to Clipboard.
Then paste the flow here. In order to make flow usable it is necessary to surround it with three backticks (also known as a left quote or backquote `````)
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/modbus-read-node-via-modbus-tcp-in-node-red/101365)._
