# Modernization survey results now available
**URL:** <https://discourse.nodered.org/t/modernization-survey-results-now-available/99830>\
**Category:** News\
**Created:** [1 December 2025 17:15 UTC](https://discourse.nodered.org/t/modernization-survey-results-now-available/99830 "2025-12-01T17:15:37Z")\
**Author:** ![gregorius](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/gregorius/32/73816_2.png) [@gregorius](https://discourse.nodered.org/u/gregorius)\
**Post date:** [1 December 2025 18:03 UTC](https://discourse.nodered.org/t/modernization-survey-results-now-available/99830/2 "2025-12-01T18:03:21Z")
> We can see that version control appears again as the #1 blocker with 40% for production-users versus only 16% for hobbyists.
There is a tool that I created which allows - visual comparison - of deployed flow and editor flow --\> [flowcompare](https://flows.nodered.org/node/@gregoriusrippenstein/node-red-contrib-flowcompare). Basically it solves the "blue dot" & "red deploy button" - what did I change situation.
A more extensive visual control solution are the [flowhub nodes](https://flows.nodered.org/node/@gregoriusrippenstein/node-red-contrib-flowhub) which manage flow storage to github. The workflow FlowHub supports is storing individual flows to a github repository and being able to compare those flows - visually inside NR - before pushing updates to github. It also allows for multiple repositories so that - for example - I can store flows to private repositories and others to a public repositories.
I recently demonstrated how I use this by creating a VDA 5050 [simulation flow](https://github.com/gorenje/vda5050_erlang_red) combining Erlang-Red and Node-RED. In that example, I also demonstrated how I can share flows between the two NR instances using FlowHub - thus I can share flows across multiple instances of NR or Erlang-Red or Erlang-Red and Node-RED.
> Debugging flows is the top frustration for hobbyists at 27%, while production-users seem more comfortable here at 20%,
I would suggest trying [clamp mode](https://discourse.nodered.org/t/should-debug-nodes-be-capable-of-passing-the-message-forwards/95044/103) to see message flows in live without deploying or adding debug nodes. This is part of the [introspection](https://flows.nodered.org/node/@gregoriusrippenstein/node-red-contrib-introspection) package.
_[View the full topic](https://discourse.nodered.org/t/modernization-survey-results-now-available/99830)._
