Multi-state switch + passthrough / msg parts
Hello again! Wondering if you could take a look at this 3 toggle switch UI template config. The switches work perfectly when toggled manually, but doing it programmatically( topic = "b", payload = "b_on") generates a lot of duplicate messages, and on initialization I get a whole page. Thank you.
<div class="sw" style="margin-top: 1px" layout="row">
<div style="margin-left: 7px" ng-cloak>
    <md-switch id="B" ng-model="data.b" aria-label="B" ng-true-value="'b_on'" ng-false-value="'b_off'" ng-change="onChange(data.b)">B</md-switch>
</div>
<div style="margin-left: 5px"  ng-cloak>
    <md-switch id="G" ng-model="data.g" aria-label="G" ng-true-value="'g_on'" ng-false-value="'g_off'" ng-change="onChange(data.g)">G</md-switch>
</div>
<div style="margin-left: 15px" ng-cloak>
    <md-switch id="S" ng-model="data.s" aria-label="G" ng-true-value="'s_on'" ng-false-value="'s_off'" ng-change="onChange(data.s)">SIM</md-switch>
</div>
</div>
<script>
    (function(scope) {
        scope.data = {
            b: 'b_on',
            g: 'g_off',
            s: 's_on'
        scope.onChange = function(cbState) {
            scope.send({payload: cbState, topic: "switch" });
        //handle arriving messages
            if(msg !== undefined && msg !== null){
                try{
                    switch(msg.topic) {
                        case "b":
                            scope.$applyAsync(function(){
                                scope.data.b = msg.payload;
                            scope.onChange(scope.data.b);
                        break;
                        case "g":
                                scope.data.g = msg.payload;
                            scope.onChange(scope.data.g);
                        break;
                        case "s":
                                scope.data.s = msg.payload;
                            scope.onChange(scope.data.s);
                        break;
                        default:
                        break;
                }catch(err){
                    console.error(err);
    })(scope);
</script>
Unchecked Pass through messages from input and only get one output message. This should solve your duplicate message issue. The initialization swarm must be down to the input. Stick a debug node on input to find the culpret.
[{"id":"7f125b642d47076c","type":"ui_template","z":"d69bda8308d00eeb","group":"1e6261b74bfa30c0","name":"","order":1,"width":0,"height":0,"format":"<div class=\"sw\" style=\"margin-top: 1px\" layout=\"row\">\n\n<div style=\"margin-left: 7px\" ng-cloak>\n    <md-switch id=\"B\" ng-model=\"data.b\" aria-label=\"B\" ng-true-value=\"'b_on'\" ng-false-value=\"'b_off'\" ng-change=\"onChange(data.b)\">B</md-switch>\n</div>\n<div style=\"margin-left: 5px\"  ng-cloak>\n    <md-switch id=\"G\" ng-model=\"data.g\" aria-label=\"G\" ng-true-value=\"'g_on'\" ng-false-value=\"'g_off'\" ng-change=\"onChange(data.g)\">G</md-switch>\n</div>\n<div style=\"margin-left: 15px\" ng-cloak>\n    <md-switch id=\"S\" ng-model=\"data.s\" aria-label=\"G\" ng-true-value=\"'s_on'\" ng-false-value=\"'s_off'\" ng-change=\"onChange(data.s)\">SIM</md-switch>\n</div>\n\n</div>\n\n<script>\n    (function(scope) {\n        scope.data = {\n            b: 'b_on',\n            g: 'g_off',\n            s: 's_on'\n        };\n        \n        scope.onChange = function(cbState) {\n            scope.send({payload: cbState, topic: \"switch\" });\n        };\n        \n        //handle arriving messages\n        scope.$watch('msg', function(msg) {\n            if(msg !== undefined && msg !== null){\n                try{\n                    switch(msg.topic) {\n                        case \"b\":\n                            scope.$applyAsync(function(){\n                                scope.data.b = msg.payload;\n                            });\n                            scope.onChange(scope.data.b);\n                        break;\n                        case \"g\":\n                            scope.$applyAsync(function(){\n                                scope.data.g = msg.payload;\n                            });\n                            scope.onChange(scope.data.g);\n                        break; \n                        case \"s\":\n                            scope.$applyAsync(function(){\n                                scope.data.s = msg.payload;\n                            });\n                            scope.onChange(scope.data.s);\n                        break;                          \n\n                        default:\n                        break;\n                    }\n                }catch(err){\n                    console.error(err);\n                }\n            }\n        });\n    })(scope);\n</script>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":680,"y":1060,"wires":[["77654f66361ec1a1"]]},{"id":"fc01fa1c46ac8ae9","type":"inject","z":"d69bda8308d00eeb","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"g","payload":"g_on","payloadType":"str","x":470,"y":1060,"wires":[["7f125b642d47076c"]]},{"id":"77654f66361ec1a1","type":"debug","z":"d69bda8308d00eeb","name":"debug 25","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":920,"y":1060,"wires":[]},{"id":"1e6261b74bfa30c0","type":"ui_group","name":"Group 4","tab":"7e13e6107768d821","order":4,"disp":true,"width":6},{"id":"7e13e6107768d821","type":"ui_tab","name":"CRYPTO","icon":"dashboard","order":8,"disabled":false,"hidden":false}]
Thanks, singe input solved. The swarm continues. This the defaults initialization function, not seeing the issue. Basically could be one or both switched turned on with "b" being the default on.
msgB = {}; msgG = {}
let topic = msg.topic
let exchange = "Binance"
msgB.topic = "b"
msgG.topic = "g"
if(topic === "exchange") {exchange = msg.payload } else {exchange = "Binance"}
if(exchange === "Binance") {
  msgB.payload = "b_on"
  msgG.payload  = "g_off"
if(exchange === "Gate.io") {
  msgB.payload = "b_off"
  msgG.payload  = "g_on"
return [msgB, msgG]
This should be
let msgB = {}
let msgG = {}
This function is not going to generate a swarm so it must be wherever the input msg is coming from. How are you feeding the 2 outputs into the uiTemplate node?
This stand-alone flow
        "id": "e960b1e1d199e066",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "20d7abbc73464451",
        "type": "ui_template",
        "z": "e960b1e1d199e066",
        "group": "a5ba0b01d5e9a353",
        "name": "3 SW",
        "order": 5,
        "width": "2",
        "height": "1",
        "format": "<style>\n\n.sw md-switch.md-checked .md-thumb-container {\n    transform: none !important;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch.md-checked:not([disabled]) .md-thumb {\n    background-color: #ccc;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch .md-bar .myswitch{\n    background-color: rgba(111, 111, 111, 0.5);\n    display: none;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch.md-checked:not([disabled]) .md-thumb {\n    background-color: #609f70;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch .md-bar {\n    background-color: rgba(111, 111, 111, 0.5);\n    display: none;\n}\n\n.sw md-switch .md-container {\n    margin-right: 3px;\n    width: 25px;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch .md-thumb {\n    background-color: red;\n}\n\nmd-switch {\n    align-items: center;\n    height: 30px;\n    line-height: 18px;\n    margin: 0px;\n    margin-left: inherit;\n    margin-right: 16px;\n}\n\n.sw md-switch .md-label {\n    font-size: 13px;\n    color: #728faa;\n    letter-spacing: 1px;\n    font-weight: bold;\n}\n\nmd-switch .md-thumb .md-ripple-container {\n    display: none;\n}\n\n</style>\n\n<div class=\"sw\" style=\"margin-top: 1px\" layout=\"row\">\n\n<div style=\"margin-left: 7px\" ng-cloak>\n    <md-switch id=\"B\" ng-model=\"data.b\" aria-label=\"B\" ng-true-value=\"'b_on'\" ng-false-value=\"'b_off'\" ng-change=\"onChange(data.b)\">B</md-switch>\n</div>\n<div style=\"margin-left: 5px\"  ng-cloak>\n    <md-switch id=\"G\" ng-model=\"data.g\" aria-label=\"G\" ng-true-value=\"'g_on'\" ng-false-value=\"'g_off'\" ng-change=\"onChange(data.g)\">G</md-switch>\n</div>\n<div style=\"margin-left: 15px\" ng-cloak>\n    <md-switch id=\"S\" ng-model=\"data.s\" aria-label=\"G\" ng-true-value=\"'s_on'\" ng-false-value=\"'s_off'\" ng-change=\"onChange(data.s)\">SIM</md-switch>\n</div>\n\n</div>\n\n<script>\n    (function(scope) {\n        scope.data = {\n            b: 'b_on',\n            g: 'g_off',\n            s: 's_on'\n        };\n        \n        scope.onChange = function(cbState) {\n            scope.send({payload: cbState, topic: \"switch\" });\n        };\n        \n        //handle arriving messages\n        scope.$watch('msg', function(msg) {\n            if(msg !== undefined && msg !== null){\n                try{\n                    switch(msg.topic) {\n                        case \"b\":\n                            scope.$applyAsync(function(){\n                                scope.data.b = msg.payload;\n                            });\n                            scope.onChange(scope.data.b);\n                        break;\n                        case \"g\":\n                            scope.$applyAsync(function(){\n                                scope.data.g = msg.payload;\n                            });\n                            scope.onChange(scope.data.g);\n                        break; \n                        case \"s\":\n                            scope.$applyAsync(function(){\n                                scope.data.s = msg.payload;\n                            });\n                            scope.onChange(scope.data.s);\n                        break;                          \n\n                        default:\n                        break;\n                    }\n                }catch(err){\n                    console.error(err);\n                }\n            }\n        });\n    })(scope);\n</script>",
        "storeOutMessages": true,
        "fwdInMessages": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 810,
        "y": 440,
                "fdea08aa8ad586f2"
        "id": "81688b60b73259ef",
        "type": "function",
        "name": "exchange",
        "func": "let msgB = {}; let msgG = {}\n\nlet topic = msg.topic\n\n\nmsgB.topic = \"b\"\nmsgG.topic = \"g\"\n\n\nif(topic === \"exchange\") {exchange = msg.payload } else {exchange = \"Binance\"}\n\nif(exchange === \"Binance\") {\n\n  msgB.payload = \"b_on\"\n  msgG.payload  = \"g_off\"\n\n    \n} \n\nif(exchange === \"Gate.io\") {\n\n  msgB.payload = \"b_off\"\n  msgG.payload  = \"g_on\"\n}  \n\n\nreturn [msgB, msgG]",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 660,
        "y": 440,
                "20d7abbc73464451"
                "20d7abbc73464451"
        "id": "fdea08aa8ad586f2",
        "type": "debug",
        "name": "debug 33",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 960,
        "y": 440,
        "id": "79b805e8027c6a5f",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "exchange",
        "payload": "Binance",
        "payloadType": "flow",
        "x": 520,
        "y": 440,
                "81688b60b73259ef"
        "id": "a5ba0b01d5e9a353",
        "type": "ui_group",
        "name": "RIGHT",
        "tab": "7e13e6107768d821",
        "order": 4,
        "disp": false,
        "width": "12",
        "collapse": false,
        "className": ""
        "id": "7e13e6107768d821",
        "type": "ui_tab",
        "name": "CRYPTO",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
with this function
msgB.topic = "b"
msgG.topic = "g"
return [msgB, msgG]
is generating this swarm (actually now a lot smaller)
I have two outputs in the function because I couldn't figure out a different way to send two different sets with two different topics (since I need to set both switches) ... not sure if that's the best way to do it.
You are getting that because of the two inputs.
I have shown an alternative way of processing the input using payload.g & payload.b. It may not meet your needs, but it might give you some ideas
Why are you using scope.$applyAsync it is causing the uiTemplate node output to be 1 input behind? I got rid of it and the node still works. If you have to use it put the scope.onChange(scope.data.*) inside the function.
[{"id":"739de59a292077a9","type":"ui_template","z":"d69bda8308d00eeb","group":"1e6261b74bfa30c0","name":"3 SW","order":5,"width":"5","height":"1","format":"<style>\n\n.sw md-switch.md-checked .md-thumb-container {\n    transform: none !important;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch.md-checked:not([disabled]) .md-thumb {\n    background-color: #ccc;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch .md-bar .myswitch{\n    background-color: rgba(111, 111, 111, 0.5);\n    display: none;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch.md-checked:not([disabled]) .md-thumb {\n    background-color: #609f70;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch .md-bar {\n    background-color: rgba(111, 111, 111, 0.5);\n    display: none;\n}\n\n.sw md-switch .md-container {\n    margin-right: 3px;\n    width: 25px;\n}\n\n.nr-dashboard-theme .nr-dashboard-template md-switch .md-thumb {\n    background-color: red;\n}\n\nmd-switch {\n    align-items: center;\n    height: 30px;\n    line-height: 18px;\n    margin: 0px;\n    margin-left: inherit;\n    margin-right: 16px;\n}\n\n.sw md-switch .md-label {\n    font-size: 13px;\n    color: #728faa;\n    letter-spacing: 1px;\n    font-weight: bold;\n}\n\nmd-switch .md-thumb .md-ripple-container {\n    display: none;\n}\n\n</style>\n\n<div class=\"sw\" style=\"margin-top: 1px\" layout=\"row\">\n\n<div style=\"margin-left: 7px\" ng-cloak>\n    <md-switch id=\"B\" ng-model=\"data.b\" aria-label=\"B\" ng-true-value=\"'b_on'\" ng-false-value=\"'b_off'\" ng-change=\"onChange(data.b)\">B</md-switch>\n</div>\n<div style=\"margin-left: 5px\"  ng-cloak>\n    <md-switch id=\"G\" ng-model=\"data.g\" aria-label=\"G\" ng-true-value=\"'g_on'\" ng-false-value=\"'g_off'\" ng-change=\"onChange(data.g)\">G</md-switch>\n</div>\n<div style=\"margin-left: 15px\" ng-cloak>\n    <md-switch id=\"S\" ng-model=\"data.s\" aria-label=\"G\" ng-true-value=\"'s_on'\" ng-false-value=\"'s_off'\" ng-change=\"onChange(data.s)\">SIM</md-switch>\n</div>\n\n</div>\n\n<script>\n    (function(scope) {\n        scope.data = {\n            b: 'b_on',\n            g: 'g_off',\n            s: 's_on'\n        };\n        \n        scope.onChange = function(cbState) {\n            scope.send({payload: cbState, topic: \"switch\" });\n        };\n        \n        //handle arriving messages\n        scope.$watch('msg', function(msg) {\n            if(msg !== undefined && msg !== null){\n                try{\n                    switch(msg.topic) {\n                        case \"Binance\":\n                        case \"Gate.io\":\n                            //scope.$applyAsync(function(){\n                                scope.data.b = msg.payload.b;\n                                scope.data.g = msg.payload.g;\n                            //});\n                            scope.onChange(scope.data);\n                        break; \n                        case \"s\":\n                            scope.$applyAsync(function(){\n                                scope.data.s = msg.payload;\n                            });\n                            scope.onChange(scope.data.s);\n                        break;                          \n\n                        default:\n                        break;\n                    }\n                }catch(err){\n                    console.error(err);\n                }\n            }\n        });\n    })(scope);\n</script>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":750,"y":1200,"wires":[["31f5a9de15f6c819"]]},{"id":"c1ec7bd453fa1a1c","type":"function","z":"d69bda8308d00eeb","name":"exchange","func":"let msgB = {}; let msgG = {}\n\nlet topic = msg.topic\nlet exchange = ''\n\nlet newPayload = {}\n\nif(topic === \"exchange\") {exchange = msg.payload } else {exchange = \"Binance\"}\n\nif(exchange === \"Binance\") {\n\n  newPayload.b = \"b_on\"\n  newPayload.g  = \"g_off\"\n\n} \n\nif(exchange === \"Gate.io\") {\n\n  newPayload.b = \"b_off\"\n  newPayload.g  = \"g_on\"\n\n}  \n\nmsg.topic = exchange\nmsg.payload = newPayload\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":560,"y":1200,"wires":[["739de59a292077a9","17259ab11c63879e"]]},{"id":"31f5a9de15f6c819","type":"debug","z":"d69bda8308d00eeb","name":"debug 33","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":1200,"wires":[]},{"id":"9c4fd8b5d1548133","type":"inject","z":"d69bda8308d00eeb","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"exchange","payload":"Gate.io","payloadType":"str","x":340,"y":1200,"wires":[["c1ec7bd453fa1a1c"]]},{"id":"17259ab11c63879e","type":"debug","z":"d69bda8308d00eeb","name":"debug 34","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":780,"y":1140,"wires":[]},{"id":"1e6261b74bfa30c0","type":"ui_group","name":"Group 4","tab":"7e13e6107768d821","order":4,"disp":true,"width":6},{"id":"7e13e6107768d821","type":"ui_tab","name":"CRYPTO","icon":"dashboard","order":8,"disabled":false,"hidden":false}]
Oh, the payload.g | payload.b approach is much better, didn't think of it.
The scope.$applyAsync is a remnant from the original configuration, I wasn't entirely sure why it was there.
I tried the flow that you sent back (standalone, no changes) - getting 3 duplicate msg instead of 1
Very weird, I only get 1. What do you get out of debug 34?
Yes, weird, the output seems to have normalized on my end. I noticed that you brought in some of the logic into the template itself; I actually really need a "generic" solution.
Could I ask you to do one my pass please. Forget that input function, exchange variable logic, etc. I just want to be able to control the 3 switches independently (in any combination) with a single msg.payload - i.e. "b" on; "g" off; "s" on. Thank you so much!
I have made some comments in the uiTemplate node on how to change the way the outputs are presented
This version
  • does not send any data when initialised
  • uses payload.b, payload.g, payload.s for both input and output
  • values of switches are 'on' and 'off' (so initialisation input would be msg.payload.b = 'on', the output would be the same when a switch is changed).
[{"id":"7f125b642d47076c","type":"ui_template","z":"d69bda8308d00eeb","group":"1367e4a4e42824b6","name":"New Input","order":2,"width":5,"height":1,"format":"<div class=\"sw\" style=\"margin-top: 1px\" layout=\"row\">\n\n<div style=\"margin-left: 7px\" ng-cloak>\n    <md-switch id=\"B\" ng-model=\"data.b\" aria-label=\"B\" ng-true-value = \"'on'\" ng-false-value = \"'off'\" ng-change=\"onChange('b')\">B</md-switch>\n</div>\n<div style=\"margin-left: 5px\"  ng-cloak>\n    <md-switch id=\"G\" ng-model=\"data.g\" aria-label=\"G\" ng-true-value = \"'on'\" ng-false-value = \"'off'\" ng-change=\"onChange('g')\">G</md-switch>\n</div>\n<div style=\"margin-left: 15px\" ng-cloak>\n    <md-switch id=\"S\" ng-model=\"data.s\" aria-label=\"G\" ng-true-value = \"'on'\" ng-false-value = \"'off'\" ng-change=\"onChange('s')\">SIM</md-switch>\n</div>\n\n</div>\n\n<script>\n    (function(scope) {\n        scope.data = {\n            b: 'on',\n            g: 'off',\n            s: 'on'\n        };\n\n        // To send state of all switches when any one switch changes state\n        //    replace \n        // {[cbSwitch]: scope.data[cbSwitch]}\n        //    with\n        // scope.data\n        scope.onChange = function(cbSwitch) {\n            scope.send({payload: {[cbSwitch]: scope.data[cbSwitch]}, topic: \"switch\" })\n\n        }\n        \n        //handle arriving messages\n        scope.$watch('msg', function(msg) {\n            if(msg !== undefined && msg !== null){\n                try {\n                    let inputData = ''\n                    for (const property of Object.keys(msg.payload)) {\n                        if ('bgs'.includes(property)) {\n                            inputData = msg.payload[property].toLowerCase()\n                            if (inputData === 'off' || inputData === 'on') {\n                                scope.data[property] = inputData\n\n                                // scope.onChange(property) //here to send a msg for each switch on initialisation\n\n                            }\n                        }\n\n                    }\n\n                    // scope.send(scope.data) //here to send a msg for all switches on initialisation\n                    \n                } catch(err){\n                    console.error(err)\n                }\n            }\n        });\n    })(scope)\n</script>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":680,"y":1060,"wires":[["77654f66361ec1a1"]]},{"id":"fc01fa1c46ac8ae9","type":"inject","z":"d69bda8308d00eeb","name":"","props":[{"p":"payload.b","v":"on","vt":"str"},{"p":"payload.g","v":"off","vt":"str"},{"p":"payload.s","v":"off","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Start","x":470,"y":1060,"wires":[["7f125b642d47076c"]]},{"id":"77654f66361ec1a1","type":"debug","z":"d69bda8308d00eeb","name":"Switch Out","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":1060,"wires":[]},{"id":"1367e4a4e42824b6","type":"ui_group","name":"Right","tab":"7e13e6107768d821","order":3,"disp":true,"width":24,"collapse":false,"className":""},{"id":"7e13e6107768d821","type":"ui_tab","name":"CRYPTO","icon":"dashboard","order":8,"disabled":false,"hidden":false}]
Thank you, it's exactly what I was looking for! I am still experiencing the issue of duplicated outputs (right double of what it should be), and only when the switch is triggered programmatically (not manually).
I noticed that it happens when other "continuous" routines are running (like stream of data coming from an api) - if the routines are paused, the output becomes normal. What's particularly odd it that it's happening even while the switch is not connected to anything else - just the standalone flow that you sent back. I managed to suppress the duplicates by adding a "dedupe" node. Does any of it make sense?
Short answer, no. I don't get any output until I click on a switch. :thinking:
I actually need the output to set defaults, so I uncommented the relevant statement. All works as expected except for unexplained duplicates that seem to be triggered by other routines in the app (even thought it's disconnected from the rest).
