Mustache template can only display info from one object in payload
Not sure what your issue is as html created with mustache displays fine in my browser
p.s. The forum provides a way of sharing flow json, it is preferred if you use this method.
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
Also most will not have access to your data base so it is helpful if you provide a sample of the sql responses for testing, Use debug nodes to get this data in the correct format
BX00Cy7yHi
[edit]
Your issues is that the keywords and feeds are in payload and there is a seperate msg.keywords. Set your debug to see complate message object.
the template should be
<select class="form-control" id="urlname" name="urlname">
                        {{#payload.feeds}}
                        <option value="{{name}}">{{name}}</option>
                        {{/payload.feeds}}
                    </select>
                    <label for="urlname2">URL Name2</label>
                    <select class="form-control" id="urlname2" name="urlname2">
                        {{#payload.keywords}}
                        <option value="{{expression}}">{{expression}}</option>
                        {{/payload.keywords}}
                    </select>
