# Mysql database in dropdown node
**URL:** <https://discourse.nodered.org/t/mysql-database-in-dropdown-node/11144>\
**Created:** [15 May 2019 06:35 UTC](https://discourse.nodered.org/t/mysql-database-in-dropdown-node/11144 "2019-05-15T06:35:26Z")\
**Showing post:** 12
**Author:** ![bakman2](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/bakman2/32/6207_2.png) [@bakman2](https://discourse.nodered.org/u/bakman2)\
**Post date:** [21 May 2019 07:42 UTC](https://discourse.nodered.org/t/mysql-database-in-dropdown-node/11144/12 "2019-05-21T07:42:08Z")
> [@How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506/):
_[View the full topic](https://discourse.nodered.org/t/mysql-database-in-dropdown-node/11144)._
