# MYSQL database to chart
**URL:** <https://discourse.nodered.org/t/mysql-database-to-chart/42973>\
**Created:** [21 March 2021 21:50 UTC](https://discourse.nodered.org/t/mysql-database-to-chart/42973 "2021-03-21T21:50:15Z")\
**Post date:** [21 March 2021 22:08 UTC](https://discourse.nodered.org/t/mysql-database-to-chart/42973/2 "2021-03-21T22:08:25Z")
Welcome to the forum @victorramos99
In order to make code more readable and importable it is important to surround your code with three backticks
`like this`
You can edit and correct your post by clicking the pencil icon.
Feed the data that you are giving to the database into a debug node and compare it with the required format described in [node-red-dashboard/Charts.md at master · node-red/node-red-dashboard · GitHub](https://github.com/node-red/node-red-dashboard/blob/master/Charts.md)
If you are a complete beginner with node-red then I recommend watching this playlist: [Node-RED Essentials](https://www.youtube.com/playlist?list=PLyNBB9VCLmo1hyO-4fIZ08gqFcXBkHy-6). The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
If you search the forum for the title of your question it will find a number of hits that may be helpful.
If you are still stuck after that then come back and tell us which bit you have having difficulty with.
_[View the full topic](https://discourse.nodered.org/t/mysql-database-to-chart/42973)._
