# Need Simple Display-only Dashboard - Is RPi Zero W enough?
**URL:** <https://discourse.nodered.org/t/need-simple-display-only-dashboard-is-rpi-zero-w-enough/71024>\
**Created:** [22 November 2022 00:22 UTC](https://discourse.nodered.org/t/need-simple-display-only-dashboard-is-rpi-zero-w-enough/71024 "2022-11-22T00:22:03Z")\
**Author:** ![Trying\_to\_learn](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/trying_to_learn/32/28400_2.png) [@Trying\_to\_learn](https://discourse.nodered.org/u/Trying_to_learn)\
**Post date:** [22 November 2022 00:23 UTC](https://discourse.nodered.org/t/need-simple-display-only-dashboard-is-rpi-zero-w-enough/71024/2 "2022-11-22T00:23:23Z")
Should be enough.
Maybe this could help you.
> [@Putting raspberry Pi into kiosk mode](https://discourse.nodered.org/t/putting-raspberry-pi-into-kiosk-mode/70926):
> Not totally a node-RED subject, but a number of posts here relate to displaying sensor data, weather, power usage, CCTV, etc, data from their node-RED instance on a raspberry Pi, so thought maybe this tutorial may be useful - [How to use a Raspberry Pi in kiosk mode - Raspberry Pi](https://www.raspberrypi.com/tutorials/how-to-use-a-raspberry-pi-in-kiosk-mode/)
_[View the full topic](https://discourse.nodered.org/t/need-simple-display-only-dashboard-is-rpi-zero-w-enough/71024)._
