# Neopixel node does not send out signal
**URL:** <https://discourse.nodered.org/t/neopixel-node-does-not-send-out-signal/59438>\
**Created:** [6 March 2022 11:48 UTC](https://discourse.nodered.org/t/neopixel-node-does-not-send-out-signal/59438 "2022-03-06T11:48:29Z")\
**Showing post:** 3
**Author:** ![Trying\_to\_learn](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/trying_to_learn/32/28400_2.png) [@Trying\_to\_learn](https://discourse.nodered.org/u/Trying_to_learn)\
**Post date:** [8 March 2022 00:02 UTC](https://discourse.nodered.org/t/neopixel-node-does-not-send-out-signal/59438/3 "2022-03-08T00:02:54Z")
Hi Nick.
I have been down this road a few times. Recently as well.
Did you do the other (pre-requisite) part:
Pre-requisites
The Neopixel python driver need to be pre-installed... The easiest way to get the driver installed is to use the Unicorn HAT drivers install script... see the Pimoroni Getting Started with Unicorn HAT page.
curl -sS get.pimoroni.com/unicornhat | bash
The other thing that can cause you grief if the `/boot/config.txt` file.
There are things in there what MUST be set.
[My journey into th NeoPixel world.](https://discourse.nodered.org/t/could-someone-please-tell-me-if-they-can-get-this-node-installed-and-fully-working/58848)
You need these 4 lines to be as shown:
hdmi_force_hotplug=1
hdmi_force_edid_audio = 1
hdmi_group=2
hdmi_mode=39
Though people will argue it is only the first two, I have recently found that the last two are also needed.
_[View the full topic](https://discourse.nodered.org/t/neopixel-node-does-not-send-out-signal/59438)._
