Sorry I took so long to get back to you, yard work called while the weather was good, but it is raining now (yeah! we really need it - plus I can't do anymore yare work today!!!)
First off I would change the flow so the json
node connects to the switch
node only. In the switch
node I would do this:
this way you can spin off each command. Note there is an 'otherwise' test at the end to pickup any commands that are not accounted for. In addition, change the bottom option from 'check all rules' to 'stopping after first match'. If you want to keep rhings neat, have each output of the
switch
node connect to a link-out
node and then have a link-in
node start the processing for that command. The link-in
node could be on the same or a different tab like this:Here is a start for you to get the idea. Note I added sysmessage
node for my testing and I added an inject
node with the json data you provided and debug
nodes (debug
nodes are very helpful to see what is going on.
[{"id":"9a45101c.7396c8","type":"tab","label":"Main Process","disabled":false,"info":""},{"id":"14c7c29e.fd0d95","type":"websocket in","z":"9a45101c.7396c8","name":"rhasspywebsocket","server":"c088685e.819f78","client":"","x":110,"y":140,"wires":[["dce2c00.0282ec"]]},{"id":"dce2c00.0282ec","type":"json","z":"9a45101c.7396c8","name":"","property":"payload","action":"","pretty":false,"x":150,"y":220,"wires":[["1d78ba60.09128e","e69ea5da.140508"]]},{"id":"a7feaacc.ce00f","type":"change","z":"9a45101c.7396c8","name":"Unknown intent","rules":[{"t":"set","p":"payload","pt":"msg","to":"Wat zei u?","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":280,"wires":[["115f79c5.fc8f6e","391bb16c.719696"]]},{"id":"391bb16c.719696","type":"http request","z":"9a45101c.7396c8","name":"text to speech","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://rhasspy:12101/api/text-to-speech","tls":"","persist":false,"proxy":"","authType":"","x":880,"y":300,"wires":[[]]},{"id":"7da06eb3.99ae9","type":"mosca in","z":"9a45101c.7396c8","mqtt_port":"1883","mqtt_ws_port":8080,"name":"","username":"","password":"","dburl":"","x":110,"y":60,"wires":[[]]},{"id":"15442ef2.a33ba9","type":"inject","z":"9a45101c.7396c8","name":"","repeat":"","crontab":"","once":false,"topic":"","payload":"","payloadType":"date","x":220,"y":3240,"wires":[["251484e0.7dfde4"]]},{"id":"251484e0.7dfde4","type":"http request","z":"9a45101c.7396c8","name":"Relay off","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.85/cm?cmnd=POWER OFF","tls":"","persist":false,"proxy":"","authType":"","x":420,"y":3240,"wires":[[]]},{"id":"dd9ff9c1.1294d","type":"inject","z":"9a45101c.7396c8","name":"","repeat":"","crontab":"","once":false,"topic":"","payload":"","payloadType":"date","x":220,"y":3280,"wires":[["eb9d705b.bf926"]]},{"id":"eb9d705b.bf926","type":"http request","z":"9a45101c.7396c8","name":"Relay on","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.85/cm?cmnd=POWER ON","tls":"","persist":false,"proxy":"","authType":"","x":420,"y":3280,"wires":[[]]},{"id":"535e3a28.3a472c","type":"http request","z":"9a45101c.7396c8","name":"Relay toggle","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.85/cm?cmnd=POWER TOGGLE","tls":"","persist":false,"proxy":"","authType":"","x":430,"y":3320,"wires":[[]]},{"id":"865278ba.f4b36","type":"inject","z":"9a45101c.7396c8","name":"","repeat":"","crontab":"","once":false,"topic":"","payload":"","payloadType":"date","x":220,"y":3320,"wires":[["535e3a28.3a472c"]]},{"id":"e8d0446c.223ff8","type":"http request","z":"9a45101c.7396c8","name":"Status","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.85/cm?cmnd=STATUS","tls":"","persist":false,"proxy":"","authType":"","x":410,"y":3380,"wires":[["b4287cec.e76058"]]},{"id":"5e3dc78.b3c3738","type":"inject","z":"9a45101c.7396c8","name":"","repeat":"","crontab":"","once":false,"topic":"","payload":"","payloadType":"date","x":220,"y":3380,"wires":[["e8d0446c.223ff8"]]},{"id":"b4287cec.e76058","type":"debug","z":"9a45101c.7396c8","name":"","active":false,"console":"false","complete":"false","x":610,"y":3380,"wires":[]},{"id":"5b2c6004.0ff118","type":"comment","z":"9a45101c.7396c8","name":"HTTP control","info":"Controlling the relay via HTTP\nHTTP API in the admin page need to be turned off\nCopy the api key from the admin page\n\nURL http://<ip>/api/relay/0?apikey=<api key>&value=0\naccepted values (at the end):\n0: off\n1: on\n2: toggle","x":170,"y":3200,"wires":[]},{"id":"1d78ba60.09128e","type":"switch","z":"9a45101c.7396c8","name":"","property":"payload.intent.name","propertyType":"msg","rules":[{"t":"eq","v":"ChangeLightState","vt":"str"},{"t":"eq","v":"intent-2","vt":"str"},{"t":"eq","v":"intent-3","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":370,"y":220,"wires":[["22511653.a235aa"],["c16ef32c.3af3f"],["4d5fed79.7bcc1c"],["a7feaacc.ce00f"]]},{"id":"55058b19.42b414","type":"inject","z":"9a45101c.7396c8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"entities\":[{\"end\":23,\"entity\":\"name\",\"raw_end\":23,\"raw_start\":7,\"raw_value\":\"salonverlichting\",\"start\":7,\"value\":\"salonverlichting\",\"value_details\":{\"kind\":\"Unknown\",\"value\":\"salonverlichting\"}},{\"end\":27,\"entity\":\"state\",\"raw_end\":27,\"raw_start\":24,\"raw_value\":\"aan\",\"start\":24,\"value\":\"aan\",\"value_details\":{\"kind\":\"Unknown\",\"value\":\"aan\"}}],\"intent\":{\"confidence\":1,\"name\":\"ChangeLightState\"},\"raw_text\":\"zet de salonverlichting aan\",\"raw_tokens\":[\"zet\",\"de\",\"salonverlichting\",\"aan\"],\"recognize_seconds\":0.1270836799958488,\"slots\":{\"name\":\"salonverlichting\",\"state\":\"aan\"},\"speech_confidence\":1,\"text\":\"zet de salonverlichting aan\",\"tokens\":[\"zet\",\"de\",\"salonverlichting\",\"aan\"],\"wakeword_id\":null}","payloadType":"json","x":230,"y":100,"wires":[["9357d956.0c1f98","1d78ba60.09128e"]]},{"id":"115f79c5.fc8f6e","type":"sysmessage","z":"9a45101c.7396c8","command":"osxsay","title":"","subtitle":"","op1":"","op1type":"pay","receiver":"","name":"","x":860,"y":260,"wires":[[]]},{"id":"9357d956.0c1f98","type":"debug","z":"9a45101c.7396c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":530,"y":100,"wires":[]},{"id":"6663fdc1.05103c","type":"catch","z":"9a45101c.7396c8","name":"","scope":null,"uncaught":false,"x":700,"y":40,"wires":[["98734f41.5a76e"]]},{"id":"98734f41.5a76e","type":"debug","z":"9a45101c.7396c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":40,"wires":[]},{"id":"e69ea5da.140508","type":"debug","z":"9a45101c.7396c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":150,"y":260,"wires":[]},{"id":"22511653.a235aa","type":"link out","z":"9a45101c.7396c8","name":"to ChangeLightState","links":["fdbd5fb1.94a9a","121b5b54.e31465"],"x":580,"y":160,"wires":[],"l":true},{"id":"c16ef32c.3af3f","type":"link out","z":"9a45101c.7396c8","name":"to Command 2","links":[],"x":560,"y":200,"wires":[],"l":true},{"id":"4d5fed79.7bcc1c","type":"link out","z":"9a45101c.7396c8","name":"to Command 3","links":["fdbd5fb1.94a9a","121b5b54.e31465"],"x":560,"y":240,"wires":[],"l":true},{"id":"1c3ac4f3.1a1da3","type":"tab","label":"Change Light Status","disabled":false,"info":""},{"id":"aacfa480.0a09f","type":"template","z":"1c3ac4f3.1a1da3","name":"ChangeLightState","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Ik zet de {{ payload.slots.name }} {{ payload.slots.state}}","output":"str","x":450,"y":160,"wires":[["d55dd98b.24a048","ca8cbd60.0af828"]]},{"id":"1637d207.3bc356","type":"mqtt out","z":"1c3ac4f3.1a1da3","name":"","topic":"cmnd/sonoffsalon/power","qos":"0","retain":"","broker":"21cda8c2.c80df","x":730,"y":240,"wires":[]},{"id":"98c0bf18.bfbf28","type":"inject","z":"1c3ac4f3.1a1da3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"off","payloadType":"str","x":130,"y":260,"wires":[["1637d207.3bc356"]]},{"id":"7e4e494d.052e8","type":"inject","z":"1c3ac4f3.1a1da3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"on","payloadType":"str","x":130,"y":300,"wires":[["1637d207.3bc356"]]},{"id":"b7164ff9.19c9b","type":"comment","z":"1c3ac4f3.1a1da3","name":"MQTT control","info":"Controlling the relay via MQTT\n\nroot topic followed by relay/0/set\naccepted messages:\n0: off\n1: on\n2: toggle","x":130,"y":220,"wires":[]},{"id":"7fa7f986.e0a83","type":"function","z":"1c3ac4f3.1a1da3","name":"on_or_off","func":"\n if ((msg.payload.slots.state==\"aan\") && (msg.payload.slots.name==\"salonverlichting\"))\n {\n msg.payload=\"on\";\n } else {\n if ((msg.payload.slots.state==\"uit\") && (msg.payload.slots.name==\"salonverlichting\"))\n {\n msg.payload=\"off\";\n }\n } \n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":200,"wires":[["1637d207.3bc356","cad5791d.529658"]]},{"id":"cad5791d.529658","type":"debug","z":"1c3ac4f3.1a1da3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":200,"wires":[]},{"id":"121b5b54.e31465","type":"link in","z":"1c3ac4f3.1a1da3","name":"ChangeLightState","links":["22511653.a235aa","4d5fed79.7bcc1c"],"x":150,"y":160,"wires":[["7fa7f986.e0a83","aacfa480.0a09f"]],"l":true},{"id":"d55dd98b.24a048","type":"sysmessage","z":"1c3ac4f3.1a1da3","command":"osxsay","title":"","subtitle":"","op1":"","op1type":"pay","receiver":"","name":"","x":700,"y":120,"wires":[[]]},{"id":"ca8cbd60.0af828","type":"http request","z":"1c3ac4f3.1a1da3","name":"text to speech","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://rhasspy:12101/api/text-to-speech","tls":"","persist":false,"proxy":"","authType":"","x":720,"y":160,"wires":[[]]},{"id":"ea72546d.3f9358","type":"comment","z":"1c3ac4f3.1a1da3","name":"Change Light Status","info":"","x":150,"y":100,"wires":[]},{"id":"c088685e.819f78","type":"websocket-listener","z":"","path":"ws://rhasspy:12101/api/events/intent","wholemsg":"false"},{"id":"21cda8c2.c80df","type":"mqtt-broker","z":"","name":"localhost:1883","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
