# Newly refreshed dashboard table shows stale data after all dashboards closed for some time
**URL:** <https://discourse.nodered.org/t/newly-refreshed-dashboard-table-shows-stale-data-after-all-dashboards-closed-for-some-time/49730>\
**Created:** [15 August 2021 04:03 UTC](https://discourse.nodered.org/t/newly-refreshed-dashboard-table-shows-stale-data-after-all-dashboards-closed-for-some-time/49730 "2021-08-15T04:03:17Z")\
**Showing post:** 6
**Post date:** [13 September 2021 14:19 UTC](https://discourse.nodered.org/t/newly-refreshed-dashboard-table-shows-stale-data-after-all-dashboards-closed-for-some-time/49730/6 "2021-09-13T14:19:09Z")
Then the small flow in the linked post is nearly exactly what you are looking for. (if the timestamp value is unique and always progressing) as every new messages creates a new row and scrolls down)
Instead of the "demo data" node feed in your data as `msg.payload` into the "store data" node. to limit the max. amount of lines (see post below linked post) to be stored update the stopre data node (max could be easily around 1-5k if nessesary)
If you do not sort your table everything should be fine.
But as your date format should be save sorted alphabetically but if you like you can format the value / timestamp field as described here: [Ui-table date sort - #4 by Christian-Me](https://discourse.nodered.org/t/ui-table-date-sort/21685/4). (use an inject node to send `msg.ui_control` JSON together with an empty payload.
_[View the full topic](https://discourse.nodered.org/t/newly-refreshed-dashboard-table-shows-stale-data-after-all-dashboards-closed-for-some-time/49730)._
