# Nice(?) and cheap ESP32+Colour display
**URL:** <https://discourse.nodered.org/t/nice-and-cheap-esp32-colour-display/82413>\
**Category:** Hardware\
**Created:** [27 October 2023 21:39 UTC](https://discourse.nodered.org/t/nice-and-cheap-esp32-colour-display/82413 "2023-10-27T21:39:17Z")\
**Showing post:** 69
**Author:** ![Sean-McG](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/sean-mcg/32/54677_2.png) [@Sean-McG](https://discourse.nodered.org/u/Sean-McG)\
**Post date:** [20 February 2024 23:47 UTC](https://discourse.nodered.org/t/nice-and-cheap-esp32-colour-display/82413/69 "2024-02-20T23:47:40Z")
I'm sure its supported by openHasp.
So if you get it flashed with that, I think I've seen something somewhere to get it working with NR 😜
> [@Hasp\["1"\].page\[0\].tab\[0\].btn\[0\].value\_str - too complex or run of the mill?](https://discourse.nodered.org/t/hasp-1-page-0-tab-0-btn-0-value-str-too-complex-or-run-of-the-mill/85091/16):
> I have decided to stick with this layout format as it seems to work well. In efforts to further reduce the need for data entry, I have added functionality to read a "props" property in each level of the hierarchy. This means that something like "btnStyle" can be added at the top level and will be applied to every button on that particular screen, without needing to enter it anywhere else. But it can also be set at different levels, then it applies to items below that level. If set on page the…
> [@Using openHASP with Node-Red](https://discourse.nodered.org/t/using-openhasp-with-node-red/81457/47):
> In tandem with the changes I made to the "page layout" file, I have added the ability to override aspects of the auto formatting code. These can be set in the props values and modify the way that the buttons are arranged. By default based on a given container size, X number of buttons are arranged to fit into a grid of x columns by y rows. If this is not symmetrical then by default it creates more columns than rows. This behaviour can now be switched around so there are more rows than colum…
_[View the full topic](https://discourse.nodered.org/t/nice-and-cheap-esp32-colour-display/82413)._
