first function determines if harmony set's devices on or off (status = 1 or status = 3).
if I turn devices on the shelly plug is turned on immediatly (that's the way to function on top)
this function only sets the msg.payload = "on" for the switch (that is connected to this link)
the normal msg.object.... is sent to the lower line over delay (7 sec) and so on
if I turn devices off the first function set the msg.payload to off and the switch is turned off after the delay of 7 sec as well (so harmony got enough time to first turn devices soft off with the programmed activity).
will give your suggestion a try will report back when I'm done.
is there an option to just put out a value without decimals on gauge?
I'm startpaging around for gauge valueformat for node-red and I'm just finding guys that descibe hwo to get a gauge
I can do it with a function that round everything mathematicaly correct but I would like to get the flow as clean as possible... so maybe it is even possible with just this part of gauge?
hey @cymplecy I noticed that I was wrong with those messages...
the debug node was set to msg.payload and not the whole message... that's why I didn't see everything
So I was able to send the whole object with all those different messages in one object (with payload).
Now I just want to check if the switch for my homecinema is already turned on, if tho I don't have to send the activity over node-red. Is it possible to check this inside a javascript function?
EDIT: One solution would be to just activate those Harmony Activities when the switch is pressed directly attached to the switch
EDIT2: Oh no that won't work because the switch won't send the activities
Mhhh maybe I have a solution for that but I can't find out how to access a flow or even global variable?
I was able to set this variable in function A but not able to get it in function B
the problem with crashed browser is back after a few hours of running charts on my dashboard.
If found something (https://github.com/node-red/node-red-dashboard/issues/38) that other guys got the same issue but I don't know how to solve it. The guys are telling that the values that are needed to fill a chart are all saved on the machine also if they are not needed anymore for displaying the whole graph (f.e. last 24 hours).
So my first question is: Is it possibile to only send one value every 1 minute to the chart instead of every time they change?
And is it possible to clear the cache of values that are not needed anymore?
EDIT: nevermind, fixed it while rebooting the mqtt switch
EDIT2: Problem still exists, after redeploying the flow the device status won't be shown anymore and keeps at that state. all other switches works like a charm.
the switch expects the input type to match the output - so 0 (number) is not the same as "0" (string) - etc... so unless they match the input will have no effect.
I managed to get a PIN pad on my dashboard. I have one switch that should not accidentialy pressed while doing finger stuff on my smartphone
So my idea was to enter a PIN on my new PIN pad and if the PIN is correct the switch that could be activated will be shown on the dashboard. After a given period of time the button will be hide again.
As this is a new question, please open a new thread. That way if someone has a similar issue they are more likely to find a thread that’s relevant to them
