# No debug output in side-bar. Tried lots, stuck, please help
**URL:** <https://discourse.nodered.org/t/no-debug-output-in-side-bar-tried-lots-stuck-please-help/12418>\
**Created:** [20 June 2019 07:18 UTC](https://discourse.nodered.org/t/no-debug-output-in-side-bar-tried-lots-stuck-please-help/12418 "2019-06-20T07:18:20Z")\
**Showing post:** 5
**Post date:** [20 June 2019 07:52 UTC](https://discourse.nodered.org/t/no-debug-output-in-side-bar-tried-lots-stuck-please-help/12418/5 "2019-06-20T07:52:51Z")
As suggested, post the flow you are using that does not work, so we can see. See below for how to post a flow after you have copied it to the paste buffer using the Export feature. Also tell us what hardware and operating system you are running on and how you installed node-red.
_[View the full topic](https://discourse.nodered.org/t/no-debug-output-in-side-bar-tried-lots-stuck-please-help/12418)._
