# No error with creating node topic
**URL:** https://discourse.nodered.org/t/no-error-with-creating-node-topic/71495
**Category:** General
**Created:** [30 November 2022 09:19 UTC](https://discourse.nodered.org/t/no-error-with-creating-node-topic/71495 "2022-11-30T09:19:37Z")
### Author: ![zenofmud](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/zenofmud/32/316_2.png) [@zenofmud](https://discourse.nodered.org/u/zenofmud)
#### Post date: [30 November 2022 11:59 UTC](https://discourse.nodered.org/t/no-error-with-creating-node-topic/71495/2 "2022-11-30T11:59:25Z")
@Postaria Welcome to the forum!
Could you provide the full name of the node you are using? (i.e. node-red-contrib-????)
Can you create a small example flow that shows the issue and export it and attach it to a reply. Thanks
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/no-error-with-creating-node-topic/71495)._
