"No response object"
If you use the built in exec node to call out to a python script instead it will preserve the req and res objects correctly.
Where it says simulate python node. Make sure you set msg.topic in each wire, as in example.
Thanku everyone foe your help!! I finally get the output I wanted from you solutions.
