# Node Context does not reset on redeploy
**URL:** <https://discourse.nodered.org/t/node-context-does-not-reset-on-redeploy/14733>\
**Created:** [24 August 2019 07:36 UTC](https://discourse.nodered.org/t/node-context-does-not-reset-on-redeploy/14733 "2019-08-24T07:36:02Z")\
**Showing post:** 3
**Post date:** [24 August 2019 08:16 UTC](https://discourse.nodered.org/t/node-context-does-not-reset-on-redeploy/14733/3 "2019-08-24T08:16:54Z")
> [@g4ocq](#):
> I assume as I am not specifying InFile it should be stored in memory and get re-initialsed after a change to the node, if thats not the case I am looking for a way to re-iniatalise these values when I make small changes
No. Deploying a change does not reset context.
You could create a flow that sets your context values to undefined (which is how you delete them) and start it with an Inject node configured to fire on start.
_[View the full topic](https://discourse.nodered.org/t/node-context-does-not-reset-on-redeploy/14733)._
