to edit npm config enter...
npm config edit -gto edit global config -
npm config editto edit user config
npm config edit -g to edit global confignpm config edit to edit user configweird, I've tried changing it and it doesn't reflect the change
Did you run that from the .node-red folder?
Also what did you change it from and to?
no... where can I change that in the .node-red folder? The one steve shared direct me to the npm folder in the AppData folder
I don't understand the question. What I asked was whether you were running
npm config edit
from the .node-red folder. I am not certain but I suspect it may matter which folder you are in.
Also what you changed and from what to what?
