# Node node-red-contrib-events
**URL:** <https://discourse.nodered.org/t/node-node-red-contrib-events/72741>\
**Tags:** node-red-contrib-events\
**Created:** [26 December 2022 17:36 UTC](https://discourse.nodered.org/t/node-node-red-contrib-events/72741 "2022-12-26T17:36:06Z")\
**Showing post:** 7
**Author:** ![Giamma](https://avatars.discourse-cdn.com/v4/letter/g/e47774/32.png) [@Giamma](https://discourse.nodered.org/u/Giamma)\
**Post date:** [29 December 2022 06:44 UTC](https://discourse.nodered.org/t/node-node-red-contrib-events/72741/7 "2022-12-29T06:44:35Z")
The same thing happened long time ago with the link node, this is my old post ...
> [@Link in / out - questions](https://discourse.nodered.org/t/link-in-out-questions/55274):
> Hi, in my project I have 10 flow and 5 dashboard for as many tablet. In every dashboard I have text, button, switch, gauge, ecc. ecc. and I like change, label, color text, background color, ecc. ecc. based on temperature, alarm, sensor motion, door sensor, ecc. ecc ...... To send value between flow I often use the node link in / link out, but I use these node also inside the single flow to have a better view of the same flow but at the end these node are a lot, about 12/14 for flow ..... Th…
Maybe not be connected, but once again I replace some contrib-event node with mqtt node and remaining node now work fine ....
When the node don't work I have no error in debug panel (I didn't check in the editor browser tab's dev tools console) ...
_[View the full topic](https://discourse.nodered.org/t/node-node-red-contrib-events/72741)._
