# Node-RED AWS issue
**URL:** <https://discourse.nodered.org/t/node-red-aws-issue/82183>\
**Tags:** http-in\
**Created:** [19 October 2023 10:15 UTC](https://discourse.nodered.org/t/node-red-aws-issue/82183 "2023-10-19T10:15:35Z")\
**Post date:** [19 October 2023 10:29 UTC](https://discourse.nodered.org/t/node-red-aws-issue/82183/4 "2023-10-19T10:29:41Z")
The `HTTP IN` node does not spawn a new express instance, it will use the same instance that Node RED is using, but with a different route (as configured in the configuration of the node).
So using a domain or not - you will need to specify a port on client devices.
That's not to say you can't use some form of tunnel/port forward to hide the true port - but you will need to research your options.
And remember to give this a read. 😉
[Safely accessing Node-RED over the Internet - FAQs - Node-RED Forum (nodered.org)](https://discourse.nodered.org/t/safely-accessing-node-red-over-the-internet/45024)
_[View the full topic](https://discourse.nodered.org/t/node-red-aws-issue/82183)._
