# Node red button template using CSS change colors
**URL:** <https://discourse.nodered.org/t/node-red-button-template-using-css-change-colors/26550>\
**Created:** [12 May 2020 18:58 UTC](https://discourse.nodered.org/t/node-red-button-template-using-css-change-colors/26550 "2020-05-12T18:58:09Z")\
**Post date:** [12 May 2020 19:59 UTC](https://discourse.nodered.org/t/node-red-button-template-using-css-change-colors/26550/2 "2020-05-12T19:59:21Z")
Take a look to this thread [Adding `output` function to buttons designed in `template` node](https://discourse.nodered.org/t/adding-output-function-to-buttons-designed-in-template-node/25591).
You may feel that there is too many posts to follow but the problem under the discussion same as yours. So take a time to read and do experiments, I 'm sure you can find solution from it.
_[View the full topic](https://discourse.nodered.org/t/node-red-button-template-using-css-change-colors/26550)._
