# \# node-red command gives a error
**URL:** <https://discourse.nodered.org/t/node-red-command-gives-a-error/48825>\
**Created:** [23 July 2021 18:14 UTC](https://discourse.nodered.org/t/node-red-command-gives-a-error/48825 "2021-07-23T18:14:22Z")\
**Post date:** [23 July 2021 18:18 UTC](https://discourse.nodered.org/t/node-red-command-gives-a-error/48825/2 "2021-07-23T18:18:54Z")
> [@vikozo](#):
> `FEHLER: Port wird verwendet`
Node red is already running. Probably under user context or a service. You appear to be trying to launch another instance as root.
You shouldn't really run node-red as root unless it is for a specific reason and the is no other solution.
What OS is this running on? Ubuntu? Raspian ?
_[View the full topic](https://discourse.nodered.org/t/node-red-command-gives-a-error/48825)._
