# Node-red-contrib-counter
**URL:** <https://discourse.nodered.org/t/node-red-contrib-counter/28360>\
**Created:** [15 June 2020 14:41 UTC](https://discourse.nodered.org/t/node-red-contrib-counter/28360 "2020-06-15T14:41:26Z")\
**Showing post:** 21
**Post date:** [22 June 2020 09:53 UTC](https://discourse.nodered.org/t/node-red-contrib-counter/28360/21 "2020-06-22T09:53:45Z")
> [@kxn25](#):
> So i dont need the file node?
No, you don't.
Replace it with a change node, and save/retrieve your data values as described in the node-RED documentation.
Also, if you share any flows or code, please use this method - [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506)
_[View the full topic](https://discourse.nodered.org/t/node-red-contrib-counter/28360)._
