# Node-red-contrib-onvif-nodes macOS
**URL:** <https://discourse.nodered.org/t/node-red-contrib-onvif-nodes-macos/50581>\
**Created:** [3 September 2021 13:31 UTC](https://discourse.nodered.org/t/node-red-contrib-onvif-nodes-macos/50581 "2021-09-03T13:31:56Z")\
**Showing post:** 27
**Post date:** [6 September 2021 21:15 UTC](https://discourse.nodered.org/t/node-red-contrib-onvif-nodes-macos/50581/27 "2021-09-06T21:15:36Z")
> [@madmax](#):
> The status is OK.
When I look at your corresponding screenshot, the Event node has status _ **"disconnected"** _:
![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/c/9/c91ef34e5c244f69484100f543d27403837577a3.png)
When the node is disconnected, that is normally due to wrong ip/port/username/password. But of course there can also be a bug in the code. Because the whole (dis)connect recently has been rewritten for this [issue](https://github.com/bartbutenaers/node-red-contrib-onvif-nodes/issues/9), but it is not tested yet by the people that can reproduce the issue.
But I can imagine that a disconnected node results in errors like _"TypeError: Cannot read property 'device' of undefined"_. Of course the message should become user friendly...
Does this error appear when you inject a message via the _"start listening"_ button???
> [@madmax](#):
> Yes is activated on the camera.
Ok thanks for confirming that!
> [@madmax](#):
> we did not find a device.
I don't see any node status:
![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/c/4/c4b94f461bc286288de32d2ed707d961e2f156c5.png)
Is there also no status visible when you have injected an input message, to start the discovery?
I found also a bug in my discovery node, which I need to solve somehow (see [discussion](https://discourse.nodered.org/t/object-property-becomes-undefined/50647)).
> [@madmax](#):
> the Reolink RLC-410W should be able to do it.
Seems other people with such a camera had the same [issue](https://github.com/agsh/onvif/issues/76#issuecomment-315887373) with the library that I'm using ;-(
_[View the full topic](https://discourse.nodered.org/t/node-red-contrib-onvif-nodes-macos/50581)._
