# Node-red-contrib-vcgencmd : reset throttling statistics
**URL:** <https://discourse.nodered.org/t/node-red-contrib-vcgencmd-reset-throttling-statistics/15229>\
**Created:** [7 September 2019 09:49 UTC](https://discourse.nodered.org/t/node-red-contrib-vcgencmd-reset-throttling-statistics/15229 "2019-09-07T09:49:21Z")\
**Showing post:** 5
**Post date:** [7 September 2019 20:23 UTC](https://discourse.nodered.org/t/node-red-contrib-vcgencmd-reset-throttling-statistics/15229/5 "2019-09-07T20:23:50Z")
> [@BartButenaers](#):
> But by reading this [discussion](https://www.raspberrypi.org/forums/viewtopic.php?t=241736) I conclude that you CANNOT reset it?
Found [here](https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=147781&start=75#p1005529) somebody that claims it should be possible, by adding a bitmask parameter to the command:
vcgencmd get_throttled 0x7
I understand this from his explanation:
- There are two persistent values stored in the Raspberry:
  - Value A: Keep track whether the Raspberry has been throttled since reboot.
  - Value B: Keep track whether the Raspberry has been since the bitmask has been used.
- You can get hold of both of these values:
  - Get value A by calling the command without bitmask.
  - Get value B by calling the command with bitmask.
If it works like this, then I think I should implement it in my node like this:
- Add a checkbox in my config screen "_reset throttling status at every measurement_".
- Apply the bitmask when the checkbox is selected.
- Add a warning in my readme file that only a single node-red-contrib-vcgencmd node is allowed to have this option. Indeed there is only 1 value B available in your Raspberry so the nodes would start resetting each others value B ...
Is there anybody that could check whether this theory is valid?
Not sure how I could 'easily' throttle my Raspberry temporarily to experiment with this.
_[View the full topic](https://discourse.nodered.org/t/node-red-contrib-vcgencmd-reset-throttling-statistics/15229)._
