# Node-RED dashboard can't handle high freq. data
**URL:** <https://discourse.nodered.org/t/node-red-dashboard-cant-handle-high-freq-data/54265>\
**Tags:** node-red-dashboard\
**Created:** [25 November 2021 11:15 UTC](https://discourse.nodered.org/t/node-red-dashboard-cant-handle-high-freq-data/54265 "2021-11-25T11:15:49Z")\
**Showing post:** 12
**Post date:** [25 November 2021 17:17 UTC](https://discourse.nodered.org/t/node-red-dashboard-cant-handle-high-freq-data/54265/12 "2021-11-25T17:17:27Z")
Here is one example
> [@u-Plot charts simple live data example](https://discourse.nodered.org/t/u-plot-charts-simple-live-data-example/45453):
> You'll need to download the needed files from here [GitHub - leeoniya/uPlot: chart_with_upwards_trend A small, fast chart for time series, lines, areas, ohlc & bars](https://github.com/leeoniya/uPlot) and then serve them from your static folder. If performance matters and you are ready for a bit of JavaScript struggle, It is the way to go. Here's the starting point [{"id":"d03aad8c.fcdf9","type":"ui\_template","z":"c0ddb509.b04f48","group":"304730.1de8e8d","name":"chart","order":1,"width":"15","height":"8","format":"\<script src=\"/uplot/uPlot.iife.mi…
_[View the full topic](https://discourse.nodered.org/t/node-red-dashboard-cant-handle-high-freq-data/54265)._
